Ok, I got it cabled but am not getting how to set up the menus for the Ku diseqc 1 & C diseqc 2, this is my first attempt at switching.
OK here we go
-menu
-dish settings
-scroll down to diseqc sw and hit ok
-set diseqc 1.0 to 1 (if you have KU for port 1 and C-Band for port 2)
leave the other 2 set to off
exit back out and the save
you will have to do that for each KU satellite
make sure you power the Visionsat off when adding/removing anything...dont wanna fry the receiver ir switch
Congrats on getting your KU setup working. I would love to have an antenna tower like you have. Could mount several dishes and OTA antennas on that.![]()
Done deal! Still a couple that don't work right but I'm about 90% there, thanks for the help.I'll try to clean it up with some shorter cables and hook up the Neusat tomorrow sometime. :up
another option is to use the Visionsat right now for KU and the Neusat for C-BandI'm back to switching coax inputs manually to go from C to Ku digital,
oh god you're hookedeverything works well that way, hitting my Ku sats from end to end of my LOS, that DG380 motor is sweet.
fingers crossedIceberg recommended trying an Ecoda for my application, so when it arrives I hope to be able to report I've got the BUD and the 3ABN dish system fully blended and operational via remote.![]()
have fun
at least it will allow you to use both boxes with really no issues. Just manually program in the stuff on the neusat for now and when the switches come then you can get everything back up like it should be
Had another thought (uh oh)
put the diseqc switch between the Visionsat and the Neusat. Then the Neusat would get both C & KU
visionsat loop out-----port 1 of diseqc-----neusat
line from C-Band-------port 2 of diseqc
that's another option if you have something KU to watch in HD
Visionsat you wouldn't touch settings since that is coming straight from the motor
Neusat would be KU port 1 and C-Band port 2 (as examples..depends on what port you hook what band up to)
...Said daughter said to said wife....I'm sure glad we live out in the sticks so no one can see dad sitting out in the yard watching TV".
That at least would allow you to watch KU HD on the Neusat until the ecoda comes![]()
Congrats!
I think a whole month went by before I had the courage to try to find another SAT.
My wife and I were stunned that we actually got something to work.
We were screaming at each other..."Don't touch it...don't touch it!"
