Record/Buffer Question
dcowboy7
676
Pequannock, NJ
Here is the scenario:
- i want to watch a show and tape it as well.
- i put on channel 2 at 9:57.
- at 10:00 the show comes on so i hit the orange record button on the remote to start taping the show on the dvr.
- at 11:00 i hit stop.
- now when i go to play it back the recording starts playing from the 9:57 time mark, because thats when i put the channel on so thats whats in the buffer....so then obviously it doesnt start playing it at the 10:00 time mark from when i hit the record button.
My question is then:
- is there any way to have the dvr start taping exactly when i hit record and not get that extra 3 minutes of buffer stuff ?
- now i know i could do a manual record at 10:00 or tune in the channel at 10:00 but im trying not to do it that way.
so is there way to do this or due to the buffer it just doesnt work that way ?
thanks.
As you have discovered, I believe any time you press the record button, it records whatever is in the buffer. If you bring up the guide and press the record button while the program is highlighted, I believe it will record only the program - with whatever default padding you have set up.
yea but that way:
- if the show is listed as 9:00 but starts late like 9:01 u still get that 1st minute of non show.
- if the show ends later than listed u lose the last minutes.
im trying to not let the clock control the recording....im trying to control start/stop myself.
There is a little "goofyness" in how this works.
Here is what I have seen and keep in mind this is what how my reciever has worked and not a explaintion of the firmware, 'cause I have no idea what it does.
Occasionally, like the OP, I'll hit record after changing to the channel and get the first few minutes of the buffer even though it's from the previous show(don't see this too much).
If I had waited for fifteen or twenty minutes into the show to hit record it would only record time slot and not the buffer.
If I had been on that channel for a while when the show started and then I hit record, I got the time slot and not the buffer.
My guess...When I change to that channel close to the next shows time slot and then hit record at the begining of the that time slot it will get the whole buffer because it's too "short" and ensures you get your show.
Hey, it's a theory...:)
Mike
DirecTV Software Release for HR20 & HR21 Receivers 0x022D 5/7
Interactive Commercials
