looking for GeosatPro 90cm in MA/NH
anis_ber
14
hello to all
i wanna have a motorized fta system including galaxy 25,i have a winegard 76cm,but many people told me that that size wouldnt be enough for galaxy 25
that's why i wanna buy geosatpro 90cm,i ve been looking for geosatpro resellers in MA or NH in vain
Satellite AV phone numbers dont answer
please if you are around boston and you know any store that sells geosatpro dishesor any other reliable dishes, please let me know
thanks
You should be able to hit galaxy 25 with your Winegard no problem. Have you tried it?
If you have already decided to buy the Geosatpro, you could purchase it from their web site, that is what I did and had no problems.
i have invacom quad LNB for circular and linear,its sort of huge lnb
The Invacom Quad can weigh down the arm on the Winegard. And being as far north as you are there can be some issues
that's why now i wanna the geosat because its bigger and it has 2 arms that help the lnb holder which is good
I know I had issues here at 44.7N
It would weight down the holder at the eneds and made the signal worse :(
yep the winegard
I have the Invacom QPH-031, and it was a weight problem on the Winegard 2076. I now use Azure Shine (same as the Geosat Pro) 90CM dishes, and the side LNB arm support struts work well to hold that beast of an LNBF in its correct place :)
I live near Boston and have been searching for years for any retailers in the area who sell dishes of the size you seek. Never could find any. Check out craigslist.com for your area. I see large dishes on there every so often. I found my Channel Master 1.2 M on craigslist in Connecticut for $60 a few years ago--had been used once or twice!!
hello to all
thanks
I do not think that you will find one in the Boston area, I own a 90 CM Geosatpro (no I do not want to sell it) and purchased it from dvbhardware.com, he is located in RI but drop ships it so he does not stock them locally. Also, he is on vacation and says that he should be back early Sept.
Which is dead? LNBF or Receiver?
LNB adapter
