i am in 62626 the azemuth is 197 and elevation is 43 so i would asume with a 20 degree window i need to be clear of trees from 207 to 187 on azemuth would i still need a window for elevation like 33 to 53
hello i am putting in a slimline tomorrow in a very wooded area.
but i believe i can get a signal.today i purchased a tandem suunto and i have never used one before.
woul anyone know what i would need to be within on the azemuth and elevation?![]()
with your zip code you can use this link.......Satellite Azimuth And Elevation Position Calculatorhello i am putting in a slimline tomorrow in a very wooded area.
True, but you still need to allow a few degrees on each side to allow for tree growth or you'll be having signal issues within a couple of months.Go here: Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
Then select a sat at 99 and another at 119 to get the azimuths and elevations for each. This will give you the window needed. Then select the 5LNB to get the pointing values for the 5LNB dish.
Hey Guys, New here... Ive been reading quite a bit and cant figure out my problem.
I am trying to point my slimline 5lnb AU9. All i can get is transponders 22 thru 32 to have a signal even as high has 98, but 0's on everything else. What am I doing wrong.
thank
you
Mac
thank
you
Mac
yea that makes sense i will have to try it... I did spin dish around never got anything. will have to play the my elevation i guess. all my numbers match the reciever i tried the angles given on dishpointer and still got nothing but better strengths on transponders 22 - 32... i think i am on 119. but still get nothing 101 any advise to help get something on 101????
