Is my dish misaligned?
MountainHawk
3
I have 5lnb slimline dish, and the 101 (all above 90), 110 (91, 80, 82), and 119 satellites (all above 93) come in just fine; but 99(c) is in the 60s and 70s, 99(s) has 0 for about half the transponders, 51 for #3, and then 85 and up for the others (no pattern); 103(s) has mostly zeroes, with a 44, 52, 80, 97, 96 thrown in; and then 103(c) all is between 40 and 60.
Does it need to be tweaked a little?
It could be tweaked a little ....
Are you getting all your subbed channels ? If so, don't worry about them.
Mainly the 99 and 103 need adjusting.
This is done with the "Fine Tune" portion of the dish.
The 101,110 and 119 are decent ...
Jimbo
Jimbo
I've had a couple of 'searching for signal' that typically go away in a few seconds, but otherwise it's fine.
Your numbers on the main sats are pretty good, your signal on the 99 and 103 need to be fine tuned, I would call and have D* come out and peak it, your not in a hurry because your getting everything, call D* and they can do it when they are in the area.
Sounds good, thanks.
