5lnb slimline dish
B
berryman14
Thread Starter
Aug 20, 2008
I am receiving good signal in the 90's on 101, 110 & 119. I have not having any luck getting any signal on 99 or 103. Can anyone give some ideas as to why I am not receiving any king of signal? Could the lnb be bad?
Jim
iwc5893
iwc5893
2,178
The desert of WA, zip code EIEIO
What type of receiver do you have, and is it set up for the 5LNB dish type? Also, do you have the BBC's installed?
It may be an alignment issue also, since the 99/103 sats have a much smaller footprint for peaking in signal.
B
berryman14
Thread Starter
Aug 20, 2008
I have an H21 receiver. I have installed another slimline dish fo my friend and received the signal with no problem. With this installation I have spent hours trying to get any kind of signal. At one time I did get about a signal of 65 on just the even transponders on the 99. There are no tree issues and the dish arm is level.
S
sat.ninja
50
So Cal
If your LNB is good, you just need to fine tune (dither) the dish. Also check for bad fittings and low freq. barrels.
B
BrianWall
Aug 25, 2008
11
How does one fine tune/dither the dish? My problem is that some HD channels will drop out while I still receive other HD channels. It got bad enough this past Saturday, to where I was 'motivated' to call DirecTV, and after going through the round robin of questions about the weather and what kind of signal strength I was getting, a DTV tech is coming to the house tomorrow. A friend, who has had DirecTV HD a little longer then I have (less than two weeks now) thinks it might be that when the guy installed the 5LNB dish, he 'neglected' to install a multiplexer/multiswitch between the dish and receiver.
Bob Nielsen
Bob Nielsen
1,721
Bainbridge Island, WA
Dithering is adjusting the dish back and forth to accurately find the center of the beam instead of peaking the signal. You could be off far enough that the 99 and 103 signals are weak but 101, 110 and 119 would still be fine. It probably will only need a small adjustment.
P
paulman182
420
18
East Kentucky
It's a good possibility that your B-band converter is either not connected, or is bad.
I am told that you can order a free replacement from DirecTV's website.
Edit: This applies to the OP who has no signal at all on 99 or 103.
T
tweet645
Oct 20, 2008
5
No BBC
I have a slimline 5 LNb with no BBc and get no 99 or 103 but think there may be a problem with 103 that is unrelated to my lack of a bbc. If must have a BBC then that is my problem as my signal levels are in the 97 and up on the other sats
Jimbo
Jimbo
64,716
4,703
NW Ohio - Buckeye Country
Unless you have the very newest DISH out, you need the BBC's.
Jimbo
Similar threads
mobiledev
Replies
5
Views
11K
iwc5893
iwc5893
V
Replies
25
Views
11K
vwsofia
V
T
Replies
6
Views
1K
Jimbo
Jimbo
L
  • Locked
Replies
5
Views
1K
Rey
M
Replies
Views
10K
mmathis
M
