OTA trouble in LEX, KY
celticben
23
3
Two of the local channels I get through the OTA tuner hooked up to my HR21 have stopped coming in. They are WKYT and WTVQ. I checked my rooftop antenna & the coax, and everything seems okay. If anyone has any suggestions, please let me know.
Check your signal strength on the OTA channels ...
Adjust your rotor.
Check with the local stations and make sure they are not having issues, when you call them ask to speak to the Chief Engineer if he's in, ask for the engineer on duty otherwise.
Many of these stations are still not up to full power, but they usually won't tell you that.
Try running you OTA set up again.
Jimbo
Check to see if they are powering the down pre Digital Conversion. Here in Minnesota two CBS Affiliates are doing that. Many folks in Northern Minnesota are screwed until Feb 17.
HR22 External HDD Support?
