Low speed data port?
smartasswhiteboy
7
I'm trying to find a DirecTv receiver to work with my KVH TracVision SF dish. Does anyone know where I can find which standard def boxes have this port?
Your questions have been answered in your other post. Directv D10 is the newest receiver all others are at least three years old made by Hughes RCA & Phillips and maybe a couple of other old manufacturers.
I appreciate your help. I am looking to bid on some boxes on ebay. Mostly D10's. You said it is the Newest box with this port. I am shopping so I am trying to find out if it is the ONLY box with Low Speed Data port. I found some Technical Bulletins yesterday on KVH.com The first bulletin dated 2/28/05 ( also about the time I purchesed the RV) says that the D10-200 and D10-300 have LSDP that are not enabled.
The next bulletin dated 4/7/2005 shows how to update the software and restore the port functionality.
The third bulletin dated 6/28/05 says the latest software updates are affecting the LSDP functionality. Customers should disconnect the low speed data cable until they find a fix for this issue.
The last bulletin is the kicker! its dated 8/23/05. it says the permanent solution is that KVH wil supply Directv customers using a D10 receiver with a RCA DRD435 receiver which has a fully functional Low Speed Data Port.
So this is why I m trying to find one of these RCA boxes on eBay, and also trying to find if there are any other receivers with this LSDP. Thanks
KVH recommends the D10 and DRD435.. I would stick with those. The D10 is square so it is a bit easier to mount/hide/secure. If you get the D10 force a software download at home and the LSDP will be enabled.
Well I have't bid on a box on eBay, because a friend of mine gave me a RCA DRD420RE box. It has a low speed data port. Does this port work on this box? I don't want to activate a box untill I'm sure it will work the dish.
Does the box even work? You will have to activate it and find out it is about a year older than a DRD435 and should have a working low speed data port.
DirecTV to be Exclusive Sponsor of SI Pictures of the Year
Lansing / Mid Michigan HD Locals on Directv
