Whatever happened to this item in the releases? I only see it listed in the 10/31 release and didn't see it in the national release in Nov. I need this functionality otherwise I'm returning my Slingbox HD Pro.
Thanks,
Jeff
Thanks,
Jeff
Can someone post simple instructions to give a Slingbox Pro-HD the ability to control a second HR20 programmed as AV1?
Once your receiver is upgraded to software version 02AF (in the next few days or week - DirecTV started rolling it out today).
Menu->Setup->Remote->Advanced.
Set the second receiver to remote code 2.
Program your remote (via the on-screen instructions) to 00002.
Setup your slingbox video input (alternate input that the second receiver is on) as a DirecTV receiver with remote code 2 (there is only one model listed with remote code 2, and it will work - regardless of the actual model number).
Let me know if you need more clarification.
Set the H20 back to the default address 00001.
Could you just put the H20 in RF mode? Or do you have to use IR?
I couldn't get RF to work. I think I have the right Remote -- RC64R is supposed to be RF, I went through the setup on the box and on the remote and the box didn't respond after I put in the code the way it told me. So I reverted to IR.
So I guess I'm left with covering up the front of the box (and it's tough to find something to obscure the signal, paper doesn't do it), until a software update allows me to tell it to use 00003 like on the HR20's.
Lets see, you couldn't get the RF to work, many can. You couldn't follow the directions above to get the H20 to use code 00001 on AV2 device.
Thanks for this info, I successfully changed the code to 00002 and can now control my seconds HR20 on my slingbox.
But now I have a problem, I have 2 HR20's and an H20 in the same room, I was able to control all 3 by setting the AV1 to 00003 for the 2nd HR20 and AV2 to 00002 for the H20. Now both the HR20 and the H20 are using code 00002 and I cannot find a way to change the code for the H20 to 00003. I don't use the H20 much (really only as a failsafe if the DVR's go belly up) but I don't want the remote to be controlling both boxes at the same time. I put something in front of the IR on the H20 so it won't "see" the codes sent from the remote, but I'd like a more elegant solution than this.
Any help would be appreciated. I have the latest software on the H20 0x4104 dated yesterday 01/24/09.
Thanks.
Dennis
Cover the HR20 set to code 00002 for now. And with RF antenna attached to the H20 receiver, enter the menu of the H20:
1. menu> parental, favs & setup> system setup> remote> IR/RF>
2. you will see either IR or RF, click whichever to reveal both
3. either press RF or RF & DONE, the remote will stop controlling the receiver, do the following on the RF remote:
a) av2
b) press and hold MUTE & SELECT for two blinks
c) enter 9 6 1
d) press CH UP key
e) enter the last 6 digits of the receiver ID #, found on a sticker in the access card compartment
f) press SELECT
Remember to tell a RF remote from IR remote, check for the FCC sticker on the back of the remote.
The remote you listed should do RF.
Edmund's steps above are right.
When I did this, I set the directv swoosh option on the remote to RF mode for the H20.
The AV1 to 00001 for the 1st HR20, and AV2 to 00002 for the second HR20.
That let the remote control all 3 and the slingbox control the 2 HR20s.
I'm not sure if you can set the AV2 mode to RF, never tried it.
For future reference - I think RF mode only works on the DirecTV swoosh remote option, not AV1/AV2.
