Hello. This my first post and hope ya'll can help.
I have C-band only reception. But first I need to describe the equipment I am using and how I have made the hook-ups/connections. Maybe someone can tell me what I am doing wrong, how to correct the problem and why what is happening is happening.
Equipment I have:
8' mesh dish,
Uniden Analog receiver (using only as a dish positioner/mover),
Sonicview 360 Elite dual tuner FTA
Chaparral feedhorn,
External polarizer/servo motor,
C-band only lnb (I do not know which brand. The label is weathered and faded.),
No switches (Diseqc, 22 khz, etc.)
The hook up/connections:
LNB straight to the Sonicview (Tuner 1, IF in),
Servo/polarizer wires to analog receiver
Wiring = Ground--black
Pulse = white
DV6V = bare wire (can't tell color)
V/H--C/KU = empty slot
RCA cables from Sonicview to one television;
Coaxial cable from "out to tv" on the analog goes to a separate television to be able to see the satellite I want to go to);
Loop out on the Sonicview (below the IF in) is not being used.
So therefore, the analog is not connected to the Sonicview.
Now, the problem:
I move from one satellite to another with the analog receiver and select the same satellite in the Sonicview, the program on the channel of the satellite I selected on the Sonicview comes in and stays on AS LONG AS THE ANALOG RECEIVER IS ON.
However, if I turn off the analog receiver, in 15 seconds to a minute, the program I selected on the Sonicview goes black and the message "No Signal" shows up.
But if I turn off both the analog receiver and the Sonicview receiver for about 30 minutes; then only turn on the Sonicview receiver I am able to watch the program without any problem.
Is is possible that I can damage something? I've only used this setup a few times.
Thanks.
Equipment I have:
8' mesh dish,
Chaparral feedhorn,
Pulse = white
Now, the problem:
Thanks.
If I can tear myself away from THIS movie channel!!! lol.
