3/18/2009 12:55pm - Uplink Activity Report - 61 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/18/2009 12:55pm - 61 changes
Uplink Comparison Range: 03/18/2009 12:24P - 03/18/2009 12:55P
Channel Additions:
5103 - PPV [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (NA)
5103 - PPV [MPEG4 SD] added to EchoStar8 77W TP 21 ConUS beam (NA)
5250(9) - KGUN [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-ABC)
5251(13) - KOLD [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-CBS)
5252(4) - KVOA [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-NBC)
5253(11) - KMSB [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-FOX)
6477(4) - WTAE [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-ABC)
6478(2) - KDKA [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-CBS)
6479(11) - WPXI [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-NBC)
6480(53) - WPGH [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-FOX)
Channel Removals:
592 - RTVI (A) removed from EchoStar3 61.5W TP 18 ConUS beam
594 - HTBA (A) removed from EchoStar3 61.5W TP 18 ConUS beam
4608 - WTAE (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-ABC)
4609 - KDKA (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-CBS)
4610 - WPXI (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-NBC)
4611 - WPGH (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-FOX)
5731 - WXIA (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-NBC)
5733 - WGCL (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-CBS)
5735 - WSB (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-ABC)
5737 - WAGA (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-FOX)
6132 - HTBA (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
6133 - RTVI (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
9467 - HDPPV (A) removed from EchoStar11 110W TP 13 ConUS beam
9467 - HDPPV (A) removed from Echostar6 72.7W TP 17 ConUS beam
Channel Moves:
7023 - KTAB [MPEG2 SD] moved from EchoStar1 148W TP 31 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(Abilene, TX-CBS)
7024 - KRBC [MPEG2 SD] moved from EchoStar1 148W TP 31 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(Abilene, TX-NBC)
7061 - KLST [MPEG2 SD] moved from EchoStar1 148W TP 15 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(San Angelo, TX-CBS)
7062 - KSAN [MPEG2 SD] moved from EchoStar1 148W TP 15 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(San Angelo, TX-NBC)
9650 - HDBTV [MPEG4 HD] moved from EchoStar9 121W TP 02 ConUS beam to EchoStar9 121W TP 17 ConUS beam (A)
9651 - HDBT2 [MPEG4 HD] moved from EchoStar9 121W TP 02 ConUS beam to EchoStar9 121W TP 17 ConUS beam (A)
15204 - WAHU1 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-N/A)
15205 - WAHU2 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-N/A)
15206 - WHTJ1 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-PBS)
15207 - WHTJ3 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-PBS)
15208 - WVAW1 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-N/A)
Channel Package Flag Changes:
583 - RADIO [MPEG AUDIO] - EchoStar1 148W TP 01 ConUS beam changed package flags (A)
583 - RADIO [MPEG AUDIO] - EchoStar3 61.5W TP 12 ConUS beam changed package flags (A)
674 - INDMU [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
674 - INDMU [MPEG2 SD] - EchoStar1 148W TP 27 ConUS beam changed package flags (A)
756 - RDSLZ [MPEG AUDIO] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
757 - TVSLZ [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
810 - RADIO [MPEG AUDIO] - Anik F3 118.7W TP 01 ConUS beam changed package flags (A)
5184(4) - WTTV [MPEG4 HD] - EchoStar5 129W TP 05 ConUS beam changed to Available (H)(Bloomington, IN-N/A)
5250(10) - WDIO [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Duluth, MN-ABC)
5250(23) - KERO [MPEG4 HD] - Ciel-2 129W TP 10 Spotbeam 32 changed to Available (H)(Bakersfield, CA-ABC)
5250(3) - KIII [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 52 changed to Available (H)(Corpus Christi, TX-ABC)
5250(35) - KAPP [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 5 changed to Available (H)(Yakima, WA-ABC)
5251(10) - KZTV [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 52 changed to Available (H)(Corpus Christi, TX-CBS)
5251(3) - KDLH [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Duluth, MN-CBS)
5252(17) - KGET [MPEG4 HD] - Ciel-2 129W TP 10 Spotbeam 32 changed to Available (H)(Bakersfield, CA-NBC)
5252(25) - KNDU [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 5 changed to Available (H)(Richland, WA-NBC)
5252(6) - KBJR [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Superior, WI-NBC)
5252(6) - KRIS [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 52 changed to Available (H)(Corpus Christi, TX-NBC)
5253(21) - KQDS [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Duluth, MN-FOX)
7934(32) - WVIRD [MPEG2 SD] - Ciel-2 129W TP 15 Spotbeam 39 changed to Available (H)(Charlottesville, VA-NBC)
8166(40) - WMGM [MPEG2 SD] - EchoStar10 110W TP 12 Spotbeam 04 changed to Available (H)(Wildwood, NJ-NBC)
8166(40) - WMGM [MPEG4 SD] - Echostar12 61.5W TP 11 Area 5 beam changed to Available (H)(Wildwood, NJ-NBC)
8417(26) - KODF [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 21 changed to Available (H)(Britton, TX-N/A)
8417(26) - KODF [MPEG4 SD] - Echostar12 61.5W TP 01 Area 3 beam changed to Available (H)(Britton, TX-N/A)
19210 - FANDO [DATA] - EchoStar11 110W TP 06 ConUS beam changed package flags (A)
Channel Renames:
9990 - DTV - EchoStar11 110W TP 08 ConUS beam renamed to ETC10 (A) (H)
Channels in the system: 6413
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
digiblur
14,190
4
Louisiana
More locals firing up...
Pittsburgh HD duplicated on 129 (probably going to be removed from 118.7)
Tucson, AZ HD's...should make lots of folks happy. But they aren't available yet.
JohnH
Godfather of the Uplink Reports
Oct 5, 2003
3,013
Kansas City, Missouri
TRANSPONDER CHANGES
CHANGE Tp 5 EchoStar 1 148w ,QPSK SR 20000 FEC 7/8
TO Tp 5 EchoStar 1 148w ,QPSK SR 20000 FEC 5/6
DELETE Tp 2 EchoStar 9 121w ,QPSK SR 20000 FEC 1/2
ADD Tp 17 EchoStar 9 121w QPSK SR 20000 FEC 1/2
djjenkins
179
Tucson, Arizona, United States
YES!!! Tucson, AZ DOES make me UBER happy! So rad! The retailer chat said they would be coming April 1st, so I am not getting my hopes up that they will show up before then, but this is great news still!
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
102,747
26,376
Newington, CT
Damn the HDPPV was removed from 9467.
Over the past few days there the channel has been in the clear showing all kinds of stuff for free including last weeks big UFC fight.
Well it was good while it lasted. :D
dennispap
1,944
499
Hammond, La.
It was an all day channel, but It only showed ufc and the playboy lingerie.:eek:
Not bad for free though:)
Scott ,
Dont forget the premiere of ROH Wrestling in hd this sat on hdnet.
8:00 PM ET/5:00 PM PT Ring of Honor Wrestling - Premiere
Ring of Honor makes its national television debut as Jerry Lynn, Tyler Black and Jimmy Jacobs take to the mat for a night of high flying action from the Arena in Philadelphia.
http://www.hd.net/schedule_sevenday.html#CMID6601
tman1991
SatelliteGuys Guru
Nov 9, 2007
137
actually why are they (Tucson locals) on 119? So why was there a long wait for 129 when they put them on 119?
M Sparks
1,946
I DO include April 1st, since Charlie said we'd have the Viacom channels "BY April 1.";)
Here's my bet on the "by April 1st" bit...Charlie is trying to work other deals out to drop a big load of new HD at once as they've done in the past. (There are 19 HD channels "warming up") April 1st is probably the day they MUST start contractually. So, if Charlie could work out all of his other deals before then, they would turn everything on early.
It's a good bet he won't work out everything he wants to, so my bet is April 1st for Viacom. Only question is, why did BETJ start early?
Kind of like last year, when USA and Sci-Fi were added on a Friday with zero fanfare... a few weeks later, they add about 20 channels and included USA/Sci-Fi in the press release.
trailerman68
Feb 19, 2009
24
Michigan
If they have duplicated the Pittsburgh HD Locals at 129 and 118.7, could this mean that the Detroit HD Locals will be doing the same in the near future??? Anybody have any thoughts on this??
