Retrofitting LNB to a 1.2 meter dish
keithb
71
Edmonton, Alberta
I would like to know if there is any way to retrofit the current 4 coax slimline 5lnb (or the newer SL3-SWM) onto an older 1.2 meter dish. The older dish has a smaller rectangle slot that housed the old single directv lnb - opening looks to be about 3/4" x 1 7/8".
I would like to avoid ordering the AK/HI 1.2 meter dish as it is cost prohibitive and I see not many dealers would ship to the great white north.
Thanks Keith
The signals from the multiple satellites will not correctly converge to the multi-LNBF from a refelector that was not designed for the specific unit. You will need a reflector that is designed for the Slimline LNBF.
I realize after posting that the larger 5 lnb won't work but how does the 99/101/103 lnb fit onto the round 1.2 meter AK/HI dish?
It works pretty well with the Phase III dish, but I am in the U.S. I am not sure how your signal would be up there...
The slimline (larger than PH III) continues to give me weak (30's) ka signals, I don't hold out much hope for the Phase III dish to pull in a reasonable signal this far north.
Here's hoping someone in Alaska is not using their Directv 1.2 and may want to unload it. I keep checking.
Anyone try a 30" or 33" dish with the Directv SL3 LNB?
Can you cut both arms and blend them together so that you have the proper opening in the arm. Basically what I did to get a single LNB to mount on a Superdish. I cut the end off of a Dish 300, then cut the end of off the superdish then bolted them together.
You may have to get inventive, but if there is a will there is a way. I just did this the other day.
FREE 72 Local Swap?
What satellites directv works with ?
