WB-68 Switch with 18" Dish Only?
sfollenius
Hi, I had an HD setup with Directv and recently cancelled and moved to Dishnetwork. My In-laws have an SD-DVR (non-TIVO) and another Standard Def Reciever hooked up to an 18" single LNB dish. They only have one input from the Dish to their SD DVR, thus they only have one tuner. Is it possible to install the WB-68 indoors and input from the LNB and use two of the outputs to gain dual tuner functionality on the SD DVR? If so, which input would they use for the scenario, (I realize this isn't what the switch is designed for).
Thanks!
You need to connect both outputs from the 18" dish to the WB68. After the dish is connected you will have 8 outputs available
Yes just connect the two cables from the 18" to the 13v and 18v. Now you have 8 SD tuners, run two lines to the dvr.
It will work just fine like this.
Has anyone actually tried this? The WB68 switch is designed for a KAKU dish, not the original 18" dish. The WB68 switch usually needs 4 inputs, not 2.
Not saying it wouldn't work, but I've never seen it.
It WILL work just fine w/an 18" dish; the instructions even say so that come with them... ;)
And actually, it will ALSO work fine with the P3 oval dishes, AS well as the international dish... ;)
Standard Def Settings on HD Receiver
Comcast SportsNet Chicago
