119 transponder issues
aquaman67
339
17
Tennessee
I have a 1000.2 dish with a 722k.
How can I have 78 signal strength on sat 119 transponder 21 and a 10 signal strength on transponder 8? It's not a spot beam either, it's channel 116.
UPDATE:
It's all the even transponders on sat 119.
8 is so low it gets no picture but all the other even transponders are low.
What causes this? Connector? Ground Block? Cable? LNB?
All the above?
Have you tried a check switch? Could be a bad switch in the LNB. Also, have you checked your grounding and all of your connectors out at the dish?
When you bring up the System Info screen (menu-6-1-3 I think) does it complain about LNB drift?
