Hello,
I was wondering if there was any place in the U.S. to buy the Vantage HD1100S other than Rick's...
Also, has anyone used the analog, SD outputs on this unit for HD signals?
Any problems doing this? Clearly, the Coolsat has analog interference on the analogs when DVB-S2 is received, the Pansat doesn't downconvert 720p correctly (you get only 240p not 480i at the output), and I've heard the AZbox has a vastly wrong black level.
Anything about the analog outputs on the Vantage? Also, does it have a simple RCA composite output, an S-Video output, or neither (ie is only the Scart the only standard-def output)? And if Scart, can you get S-Video out of the Scart with the proper adaptor?
Thanks!
--Gary
Thanks!
--Gary
