Hi guys! I am kind of stuck right now on my FTA 1.8m C/Ku dish upgrade project (weather is part of the reason). Here is what I got done so far. I have installed a 14 foot pole (2 1/2 inch inside diameter) with 4 1/2 feet buried in concrete. The inside of the pole has been filled with concrete to add stability. The pole is perfectly plumb. I have a 3/4 inch PVC conduit going under the house. I have two issues that I need to resolve before I can assemble and install the BUD on the pole. The first one is the one I'm most concerned about. The concrete has been set, but when I put my hand on the pole and try to shake it, the top of the pole moves.
This is not good - especially when I'm visualizing the BUD mounted on it. What can I do to stabilize the pole so it won't shake? I thought of two possible fixes. The first is to attach a guy wire cable (about 1/2 inch thick) to the pole and anchor it to an anchor embedded in a concrete block five or six feet away from the pole. The other possibility is to drill one or two 1-1 1/2 inch holes next to the pole about two feet deep and put in one or two 1- 1/2 inch poles, fill it with concrete, and use pipe clamps to secure it together. The last thing I need to do is to break up the concrete and re-mount the pole next to the house. The pole has been installed about 10 feet away from the house.
The second issue is minor compared to the first. My C/Ku Band LNBF has two outputs - one for C-band and one for Ku-band. How can I multiply the output of each band to connect it to a 5 x 8 switch to get both horizontal and vertical polarities and distribute the signals to different parts of the house? I presume it would not be advisable to connect to a splitter rated for satellite use to each output. Can I use an in-line amplifier to compensate for the signal loss if I use a pair of splitters? One other thing that I'm curious about is the Loop-IF output on my FTA receiver. If I had that output routed to another room, can a different receiver operate independently of the first receiver? The last thing I would want to do is to use a series of manual switches to route the output from a 2 x 1 switch to another room - one room will get FTA satellite reception while all the other rooms will not get any reception. What is the best way for me to get both horizontal and vertical polarities of both bands to provide independent reception for all the receivers in the house?
