2/17/2010 7:41pm - Uplink Activity Report - 163 changes
  • WELCOME TO THE NEW SERVER!
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/17/2010 8:37pm - 163 changes
Uplink Comparison Range: 02/17/2010 04:41P - 02/17/2010 04:56P
Channel Additions:
6800 - UP4 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6001) (NA)
6801 - UPSD [MPEG2 SD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6144) (NA)
6802 - UP2 [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6152) (NA)
6803 - UP3 [MPEG2 SD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6154) (NA)
6804 - UP7 [MPEG2 SD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6161) (NA)
6805 - UP4 [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6165) (NA)
6806 - UP8 [MPEG2 SD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6191) (NA)
6807 - UP10 [MPEG2 SD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6193) (NA)
6808 - UP9 [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6195) (NA)
6809 - UP4 [SD TV] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6201) (NA)
6810 - UP4 [MPEG2 SD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6004) (NA)
6811 - UP4 [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6005) (NA)
6813 - UP4 [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6102) (NA)
6814 - UP4 [MPEG2 SD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6103) (NA)
6815 - UP5 [MPEG2 SD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6104) (NA)
6816 - UP5 [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6105) (NA)
6817 - UP5 [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6202) (NA)
6821 - UP5 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6203) (NA)
6822 - UP5 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6204) (NA)
6826 - UP6 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6003) (NA)
6828 - UP6 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6002) (NA)
6834 - UP7 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6205) (NA)
6840 - UP8 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6254) (NA)
6841 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6252) (NA)
6842 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6503) (NA)
6844 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6504) (NA)
6845 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6505) (NA)
6846 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6552) (NA)
6847 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6554) (NA)
6848 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6571) (NA)
6849 - UP9 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6291) (NA)
6850 - UP9 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6293) (NA)
6851 - UP9 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6295) (NA)
6852 - UP9 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6301) (NA)
6853 - UP9 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6302) (NA)
6854 - UP9 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6303) (NA)
6855 - UP10 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6304) (NA)
6859 - UP10 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6305) (NA)
6861 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6354) (NA)
6862 - UP10 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6101) (NA)
6863 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6381) (NA)
6864 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6385) (NA)
6868 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6391) (NA)
6870 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6393) (NA)
6871 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6395) (NA)
6872 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6401) (NA)
6874 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6402) (NA)
6877 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6404) (NA)
6880 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6573) (NA)
6881 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6592) (NA)
6882 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6593) (NA)
6883 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6594) (NA)
6884 - UP11 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6595) (NA)
6886 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6405) (NA)
6888 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6452) (NA)
6894 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 04 Spotbeam ??(TID 6454) (NA)
6897 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6491) (NA)
6908 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 03 Spotbeam ??(TID 6493) (NA)
6914 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 05 Spotbeam ??(TID 6495) (NA)
6915 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6352) (NA)
6926 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam ??(TID 6501) (NA)
6945 - UP29 [MPEG4 HD] added to EchoStar14 119W TP 02 Spotbeam ??(TID 6502) (NA)
9531 - DNFYI [MPEG4 HD] added to Ciel-2 129W TP 27 ConUS beam (NA)
9531 - DNFYI [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (NA)
Channel Removals:
5264 - WFSU (NA) removed from Ciel-2 129W TP 14 Spotbeam 51(Tallahassee, FL-PBS)
4820 - TMP50 (NA) removed from Ciel-2 129W TP 24 ConUS beam
4827 - TMP57 (NA) removed from Ciel-2 129W TP 23 ConUS beam
Channel Moves:
4803 - TMP33 [MPEG4 HD] moved from EchoStar11 110W TP 07 ConUS beam to Ciel-2 129W TP 24 ConUS beam (NA)
4804 - TMP34 [MPEG4 HD] moved from EchoStar11 110W TP 07 ConUS beam to Ciel-2 129W TP 23 ConUS beam (NA)
Channel Package Flag Changes:
5264(16) - WUSI [MPEG4 HD] - Ciel-2 129W TP 12 Spotbeam 30 changed to Available (H)(Olney, IL-PBS)
5264(47) - WTVP [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 22 changed to Available (H)(Peoria, IL-PBS)
5265(59) - WAOE [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 22 changed to Available (H)(Peoria, IL-MY)
5254(8) - WDSE [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Duluth, MN-PBS)
5154(26) - KOZJ [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 36 changed to Available (H)(Joplin, MO-PBS)
5154(26) - KOZJ [MPEG4 HD] - Echostar12 61.5W TP 13 Spotbeam 15 changed to Available (H)(Joplin, MO-PBS)
5254(12) - WMAE [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 38 changed to Available (H)(Booneville, MS-PBS)
5264(14) - WMAW [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 43 changed to Available (H)(Meridian, MS-PBS)
5254(9) - KUSM [MPEG4 HD] - Ciel-2 129W TP 05 Spotbeam 12 changed to Available (H)(Bozeman, MT-PBS)
5254(3) - KBME [MPEG4 HD] - Ciel-2 129W TP 12 Spotbeam 7 changed to Available (H)(Bismarck, ND-PBS)
5154(13) - KFME [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 8 changed to Available (H)(Fargo, ND-PBS)
5254(13) - KTNE [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 19 changed to Available (H)(Alliance, NE-PBS)
5254(7) - WITV [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 44 changed to Available (H)(Charleston, SC-PBS)
5255(36) - WMMP [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 44 changed to Available (H)(Charleston, SC-MY)
604 - KINOE [MPEG2 SD] - Echostar12 61.5W TP 21 ConUS beam changed package flags (A)
727 - VIDIT [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
728 - RAI [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
730 - RAINW [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
735 - TRACE [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
737 - KINOE [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam changed package flags (A)
750 - EKSHY [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed package flags (A)
752 - EURCH [MPEG2 SD] - Anik F3 118.7W TP 07 ConUS beam changed package flags (A)
755 - BVISN [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed package flags (A)
804 - NTV [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
805 - RTV [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
806 - CHNLI [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
818 - ATN [MPEG2 SD] - Anik F3 118.7W TP 19 ConUS beam changed package flags (A)
908 - RAD60 [MPEG AUDIO] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
909 - RADIT [MPEG AUDIO] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
910 - RAIRD [MPEG AUDIO] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
Channel Renames:
601 - ARTSP - Anik F3 118.7W TP 17 ConUS beam renamed to ALJSP (A) (H)
601 - ARTSP - EchoStar3 61.5W TP 14 ConUS beam renamed to ALJSP (A) (H)
Transponder Changes:
EchoStar14 119W TP 01 Spotbeam ??(TID 6001) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6101) 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6161) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6191) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6201) 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6291) 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6301) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6381) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6391) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6401) 20000 QPSK 7/8 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6491) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6501) 21500 8PSK 2/3 added
EchoStar14 119W TP 01 Spotbeam ??(TID 6571) 20000 QPSK 7/8 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6002) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6102) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6152) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6202) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6252) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6302) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6352) 20000 QPSK 7/8 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6402) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6452) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6502) 21500 8PSK 2/3 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6552) 20000 QPSK 7/8 added
EchoStar14 119W TP 02 Spotbeam ??(TID 6592) 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6003) 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6103) 20000 QPSK 5/6 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6193) 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6203) 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6293) 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6303) 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6393) 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6493) 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6503) 20000 QPSK 7/8 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6573) 21500 8PSK 2/3 added
EchoStar14 119W TP 03 Spotbeam ??(TID 6593) 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6004) 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6104) 20000 QPSK 5/6 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6144) 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6154) 20000 QPSK 5/6 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6204) 20000 QPSK 5/6 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6254) 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6304) 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6354) 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6404) 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6454) 21500 8PSK 2/3 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6504) 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6554) 20000 QPSK 7/8 added
EchoStar14 119W TP 04 Spotbeam ??(TID 6594) 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6005) 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6105) 20000 QPSK 5/6 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6165) 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6195) 20000 QPSK 5/6 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6205) 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6295) 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6305) 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6385) 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6395) 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6405) 20000 QPSK 5/6 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6495) 21500 8PSK 2/3 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6505) 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam ??(TID 6595) 21500 8PSK 2/3 added
Channels in the system: 6816
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Sorry about the delay guys/gals... I had some code I put in back when I started doing the links to the spotbeams that the uplink tool was choking on when there was a new TID.
I suspect these new TIDs are for the upcoming launch of E-14.
They are adding hd to 61.5. LOL
Digiblur - i continue to be impressed with your uplinks. thanks!
Thanks.. all of the views/posts on the uplink threads make all of the work well worth it ;)
Sorry for the hang up on the report, when I coded the report to create the clickable spotbeam links I forgot to handle the situation where the beam was new and didn't have an orbital/tp description. So it got hung up when it got to the unknown data. I was just glad it wasn't getting hung up in one of the diff engines on the report...that thing is a nightmare to debug with all of the stuff going on there!
In case anyone is interested check the link below for a post I did quite a while back with the help of nelson61's map data.
http://www.satelliteguys.us/dish-ne...lite-utilization-information.html#post1842789
Time to see if I can figure out their TID numbering scheme to match up the spotbeams to the spotbeam maps.
Updated the TID database on the uplink PC. These are indeed for E14!
Great! This could be my failing memory, but I don't remember these going up before the satellite was even launched. I guess somebody is pretty confident it will make it.
If I remember correctly Ciel-2's TIDs were up before it launched... or maybe it was after it launched and before it was in place. But I do know they had a problem with some older receivers and all the TIDs, and pulled them back, so I'm sure they are making sure they don't have that issue again.
Yea, Charlie had a tough decision, he must have said to himself: "BBCA-HD or DNFYI-HD, BBCA-HD or DNFYI-HD? I'm sure people would much rather see me in 'HD' than that stupid Gordon Ramsay or Stig".
Similar threads
D
Replies
Views
2K
D
D
Replies
Views
2K
D
D
Replies
Views
2K
D
