Major problem with my H20 and pixelation!
sobonefnet
322
2
PA
I am totally confused!
I have a H20 connected directly to a 1080p Vizio via HDMI.
I have a SWM set up.
The HD channels are perfect
Every single SD channel is pixelized.
I ran system test everything is "OK"
Signal strength is 96%-99%
I switched the HDMI cables and still nothing.
What in the world could be causing this?
If it is a H20-600 then its cooked and you need a dif reciever
Have you tried using component cables? sobonefnet could be right, you could have a bad receiver, especially if it is an H20-600. There were many bad ones early on. If you can't get it working correctly, call Directv and have them send you another one. Assuming that you don't own the H20, make sure they don't extend your commitment, since it is defective.
Its a 600. I called them last night and they wanted to send a tech (and all the fees). What can I say to them to send me a new receiver. I do not own it.
Tell them it won't even turn on. That should get them to simply send you a new one. Again, make sure they don't extend your commitment for this since it is a defective unit.
OK - just got off the phone with D*, replacement receiver is on it's way via 2 day FedEx. They charged me 19.95 but, they will be no extension to my current contract. I hope they send me an H21 in stead of a H20. They told me I can keep the H20.
Now that's the way it's supposed to work. But just on the safe side, when you get the new receiver and you go to activate it talk to the access card department and make sure they note no extension when they activate it. And then to be double safe I'd e-mail them after that asking them to provide you the end date to your commitment so you have it in writing.
I have MVR on my (2) HR22's. MVR is available on the nonDVR models? I didn't know that.
It should be on the H21 and H23 with the next national release software update but not the H20 since it doesn't have an ethernet adapter in it.
I just received my shipping confirmation. this is what they sent: E®P_H20 - Model: H20-100C-R
Can you record Daves steam on an HR23?
Any experience with the IceZapper® dish heater?
