Well I have deciced to build a DVB PC receiver for play with DVB-S2 HD 4:2:0/4:2:2
OK question for you know it all about DVB cards. Can I get DVB-S2 4:2:0/4:2:2 SD/HD with MAC OS X? If so, which versions are supported?
i doubt you will have much luck with mac OS and dvb. i dont think i have seen a mac driver for any dvb cards i own... (twinhan 1027, geniatech digistar, genpix sw-1, tbs6920, dvbworld 2006, prof 7301 / 7500). id stick with an xp / linux dual boot for the best of both of those worlds.
crackt out,.
boy this MicroDVBbox is so quiet. I will report as soon as I got it going with my 1.2M dish.
OK after messing with some settings tonight, I did some text with the MicroDVBbox.
I started with XP and had some trouble with the codecs, well finally installed and set them up correctly and my test was not as I wanted it to be. Xp seems to run slow at times with my PC setup (i3 processor + DDR3 PC12000) maybe overkill??? so i decided to try my other partition.
The other OS is Windows 7 Ultimate 64bit. Installed DVBDream and VLC and amazingly it ran 1000 times better then XP.. sooo smooth I was impressed.
Here are some snap shots from VLC on some DVB-S2 H.264 feed from Azteca HD.
With my PC setup, for me Win7 64bit ran the best of the 2 OS's
We'll see how it goes with other sats and feeds. Stay tuned :up
The combo has HDMI out and using the graphics from the i3 540 chip. There is no need for a dedicated video card. Also has optical out for DD.
crackt out,.
Anyone found or know of a good starting point to look for Mac drivers and DVB cards???
