Now we get into the nitty-gritty. The camera was slowly panning across a static scene, so this is not quite as easy as the absolutely static shot in the first post in this thread. Nevertheless this is not particularly challenging except for the detail. I zoomed 300% on a portion of each HD image, and 900% on the SD images, which is the equivalent. The order is the same as in my immediately preceding post.
The DN HD isn't too bad, but one can certainly see more mosquito noise than in the master feed. There is also some detail loss overall, see for example the wood grain immediately to the right of FDR.
It was interesting to compare the simulated SD feed and the upscale. While the two have the same effective resolution, it may be a matter of personal preference which 'looks' better. The non-upscaled version may seem a bit sharper because of the more distinct edges, but the upscaled version is smoother. The bottom line is neither of these highly idealized images is at all competitive with the real-life DN HD-lite.
I won't spend a lot of time on the DN SD frame. The colors are washed out and the edges very ill-defined, but it's closer to the simulated SD 'master' than the simulated SD 'master is to DN HD-lite.
: - Yes.. I've got that continual ringing in my ears. Too much loud music on my Walkman years ago I guess.. Plus, going to concerts without ear plugs causes it too.. These days, EARPLUGS is the top thing on my list when I attend classic rock festivals. Years ago I saw Judas Priest at a small bar in Toronto. My ears rang for days. Last year I saw Judas Priest again at an outdoor event in Walker Minnesota, but I made use of the earplugs when I went down front and didn't experience any temporary hearing loss..
