DDR3 RAM
navychop
Reunite Pangea! Stop overfishing Panthalassa!
62,631
31,077
Northern VA
I have a W7 64 bit machine with, I think, Crucial memory. I'm having some problems which might be attributable to bad RAM. So I'm considering buying Kingston memory as a replacement. The motherboard is an ASUS P6T. I've long since stopped keeping up with the changes in DIMMs.
ASUS lists Qualified vendors, per the below:
KINGSTON
KHX1600C9D3K3/12GX(XMP) DDR3 1600 12288MB(Kit of 3)
DS (1066-7-7-7-20) 1.65v
KINGSTON KHX1600C9D3K2/4G DDR3 1600 4096MB(Kit of 2)
DS (1333-9-9-9-24) 1.7~1.9v
But I find the below at Amazon:
Kingston6GB 1600MHz DDR3 Non-ECC CL9 (9-9-9-27) DIMM (Kit of 3) Tall HS XMP
And at NewEgg:
Kingston HyperX 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K3/6GX
* DDR3 1600 (PC3 12800)
* Timing 9-9-9-27
* Cas Latency 9
* Voltage: 1.65V
* Multi-channel Kit: Triple Channel Kit
* Model #: KHX1600C9D3K3/6GX
I don't understand the timing numbers. I have no idea if "27" is better or worse than "24." And 7 vs 9. Granted, the size of the memory is different.
Would either of these work? What should I look for/avoid?
Timing, lower the better
KINGSTON
Knowing what the SPD is programmed for is the real number, unless you want to manually set up your memory times. Also, it depends on your motherboard if it will allow the settings.
I have never found it worth over clocking memory, I just look for SPDs that are programmed for minimum timings at the stock votage.
I don't have a tester, and the two shops I used to use for that purpose are now history. I guess I'll need to dig up a s/w test.
Long running programs such as Adaware, Spybot, Norton 360 scans, etc, eventually freeze. Notice a trend? Also, my iPhone is no longer syncing, and I've lost my Riverdance ring tone. It gives an error msg to the effect that the iPhone disconnected. Not that long ago I replaced my 3G with a 3GS. Other "mated" PCs ask if it's a new phone or to restore from an old. Don't want to answer that, as I'm not sure of the repercussions. Also, backups fail/freeze.
Looks like I'll have to look a little further for faster memory.
Thank you. Saved me time looking for one. Last one I had was on a 3.5". Err, uhhh, oh well.
I ran it overnight, 13 hours. No problems. So I guess I've got to look on the software side for problems.
Could you possibly have an overheating problem? That could certainly cause a system to lock up during a long process.
It likely would have repeated for the memory test also.
Anyway, my box has way oversized fans and vents, so that's not likely the problem.
While I don't know what you're using your machine for, you might have better luck (and save a few bucks with dual channel RAM from Kingston. I'm running 8gb of this Newegg.com - Kingston ValueRAM 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model KVR1333D3K2/4GR on my AMD 965 Phenom HTPC with an ASUS M4A79XTD EVO main board and it runs like a champ. Just my two pesos.
A lot of newer machines require triple channel memory now.
FYI Windows 7 has a memory check program build in. Can be accessed while running, it will reboot the system, or F8 during start up and start it in the boot manager.
Hmmm. Have to look in to that.
My P6T w/i7 uses triple channel.
Yes, the first i7's (9xx) were of this flavour, positioned as premium product atm.
But mainstream went the 1156-pin CPUs...
Diogen.
That sucks. I have one of the first I7's :rant::rant:
Front panel USB ports causing problems?
RadioTime, Pieker Partner On In-Car 'Net Radio
