Question on cable run?
curtishd
181
How long can the cable be from the dish to the receiver before the signal is no longer working or degrades in cold weather/ice and snow? Also anyone know of a place to but long cheap coax cable?
I think to answer the first part of his post, the length is 250 feet with SCC RG6. Using RG11 can get you longer lengths.
A SWM install can also be a bit longer.
I know you can't split a sat signal BUT can I connect 2 100ft cables and still have it work?
You should be able to connect 2 cables but keep in mind there is some loss at each connection. I run from the dish to a grounding block before entering the house. The grounding block is a connection.
Also Directv specifies solid core coax which, as I understand, has lower loss. My setup has copper-clad center core coax which works fine on the 5 lnb dish but when or if I need to replace I'd use solid copper. I bought a 500ft roll of RG6 quad-shield at Home Depot for something like $0.13/ft. Others might comment on using copper-clad vs solid copper. As stated mine works fine.... for now.
Do I need an installer if I buy an HR24?
dvd recorder vcr combo hook up help
