8/3/2010 7:10am - Uplink Activity Report - 11 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/3/2010 7:10am - 11 changes
Uplink Comparison Range: 08/02/2010 10:25P - 08/03/2010 07:09A
Channel Additions:
6822 - UP5 [MPEG4 HD] added to Echostar12 61.5W TP 17 ConUS beam (Virtual Channel) (NA)
6826 - UP6 [MPEG4 HD] added to EchoStar3 61.5W TP 18 ConUS beam (Virtual Channel) (NA)
Channel Removals:
6801 - UPSD (NA) [MPEG2 SD] removed from Echostar12 61.5W TP 17 ConUS beam (Virtual Channel)
6802 - UP2 (NA) [MPEG2 SD] removed from EchoStar3 61.5W TP 18 ConUS beam (Virtual Channel)
6813 - UP4 (NA) [MPEG2 SD] removed from EchoStar3 61.5W TP 16 ConUS beam (Virtual Channel)
6844 - UP11 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 04 ConUS beam (Virtual Channel)
6845 - UP11 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 06 ConUS beam (Virtual Channel)
Transponder Changes:
Echostar12 61.5W TP 17 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
EchoStar3 61.5W TP 16 ConUS beam 21500 8PSK 2/3 removed
EchoStar3 61.5W TP 18 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
EchoStar6 61.5W TP 06 ConUS beam 20000 QPSK 5/6 removed
Channels in the system: 7480
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.07.13a4
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
I just checked TPs 17 and 18. They are coming strong, with "E15-like" signal strength. Should the uplink show E15 instead of E12 and E3? Just curious. Also I am receiving strong signal from TP 26.
No... they won't show E15 until I change the names after they are done swapping things out. In the data the transponders are assigned numbers and for CONUS coverage the numbers do not change between satellites. Nothing is changed in the data stream if they convert a transponder straight over from one satellite to another.
Yeah digi, that's what I meant, sorry I was not clear. I know the change it's not automatic. What I meant to ask was for confirmation that these two transponders were coming from E-15.
D
7/28/2010 3:26pm - Uplink Activity Report - 74 changes
D
8/4/2010 2:51pm - Uplink Activity Report - 30 changes
