n00b question here, dish alignment?
  • WELCOME TO THE NEW SERVER!
waltah
68
NE Ohio
i have had dishnetwork for 3 years now and have never had to re-align my dishes at any point. it seems like i lose signal a little easier now when storms roll in. could this be due to the fact that the dishes may not be pointed/aligned as well as they should be? is there a way for me to check signal strength?
thanks folks.
yep go to menu then installation then point dish (or on your remote after you hit menu press 6, then 1, then 1 again)
thanks folks.
Have any trees grown enough to start to block your line of sight to the satellite?
so my dish will point itself? i thought i had to got onto the roof and do it manually?
no tree/obstruction issues.
the reason to do the menu 6-1-1 is to see what your signal strengths are for each transponder. You can scroll through the transponder and satellite list and check. They should be in the 60's or higher. If they're low (30's or low 40's) then the dish needs to be peaked.
no
peaked means slight movements of the dish to optimize signal. You can do it yourself. Again this depends on what your signal numbers are right now
ill snag the numbers once i get home tonight and see what you guys think
thanks for the help so far
Ice, on my 1000.4 system I get readings around 50 on most tp's on the 61.5° satellite but at 72.7° it is 35 to 40 on almost everything. 15 to 25 at 77° but I don't think I am looking at anything there.
Regardless of these poor numbers, the system works okay. Do you think I could stand a peaking?
You could try. I dont know the exact numbers for Eastern Arc but I thought the signals should be in the upper 50's for signal
77W probably doesnt have anything that you need. There are some HD locals on there
No with a 1000.4 system it uses diffrent sat because you can't recive the normal sat's with those numbers on those sats your fine. The reason that they are so low is becuse they are harder to get alligned to.
um no you're wrong....from what I've read the signal on 61.5 & 72 should be in the 50's
Eastern Arc is probably easier to align on the east coast as the sats are higher in the sky :)
