Hello. I never thought I would need to subscribe to satellite users's group, but its time to take control of this dish and understand what is going on here so i can troubleshoot my own problems.
The issue:
I am getting pixelating video on TV2 when viewing local programming (satellite 119 I think), whereas TV1 works fine for all channels (including local). I didn't say 'snow', I said pixilated video as if something is not being decoded/decompressed properly. You can hardly watch any local programming on TV2. Since i have a 322, both my TVS are SD, not HD.
I have read some posts about heat issues on the LNBF. I can't recall when this happens, only that is happens at the worst possible time. Yes, it failed on me during the World Cup finals! Its seems to work when there is absolutely nothing on TV (ok, i'm reaching a bit here on this one).
My configuration:
I have a dish is a Turbo HD with Dish DP Plus Digital LNBF. I think its a DispPro Plus 1000.2 Triple LNBF (the model number is A21201-WA1004KG1). The LNBF has two coax cables (plus the ground) that run from the LNBF to the grounding block. Since I only have one receiver, only one of the cables runs from the grounding block to near my receiver. I'm not sure if its port1 or port 2 of LNBF that its actually going to the the rear of my reciever via the grounding block. The rear of my receiver has a DP Plus Separator going into TV1 and TV2 of the back of my receiver (322).
The "System Info One" looks good for satellite 119 and 110, but 129 has a big-ol confederate red 'X'
. The details say there had been signal losses. There is no obstruction of trees and so clear you can see stars during the day.
I have tried:
When I enter the "Point Dish" screen and toggle the "Tuner Input" then TV2 does fine with local channels, but now TV1 is pixilated on local channels. I am getting about a 71db on Echostart 119west regardless of how "Tuner Input" is configured.
I don't understand what is going on.
I do understand that the DP Plus Separator is more than a dumb splitter, it does separate the frequencies. But what does that have to do with local programming?
* Can anyone explain to me what toggling the "Tuner Input" from "02" to "01" (or visa versa) does? and Why would this affect local channels and not all channels?
* If I want to determine if it's a LNBF problem, can I simply connect my receiver to a different LNBF Port (via the grounding block) or do I also need to make changes in the "Point Screen"?
* If i want to determine if its the DP Plus seperator, can i remove the seperator and plug it directly into the receiver (first trying 1 and then 2)
I'm trying to narrow down the problem from the LNBF, DP Plus Separator or the receiver itself. I think since I can toggle the the "Tuner Input' from "02" to '01" causes the other TV to work with local programming leads me to believe its not the tuner – but not sure.
Any advice?
Sorry for the long post, i like to document.
The issue:
My configuration:
I have tried:
Any advice?
