hi to all, when installing and fta dish do you just have to ground it to a 8 foot grounding rod,i have seen a million of dn and direct tv installs and they are merely just grounded to the block..tell me what you think.
hi to all, when installing and fta dish do you just have to ground it to a 8 foot grounding rod,i have seen a million of dn and direct tv installs and they are merely just grounded to the block..tell me what you think.![]()
It is almost never a good idea to put in a 2nd ground rod at a dish, or perhaps a better thing to say is that it is never a good idea to have a 2nd ground period. It is acceptable to BOND a 2nd ground to the house ground, effectively making it 1 ground, but that requires some massive copper cable between the two grounds. The problem is that if you have two grounds, there can be potential differences between the two grounds, which is more of a problem than not being grounded at all. But according to code, what you should do, is ground the coax from the dish at the house ground, where your electric service enters the house. As the other response indicated, there is almost always a good ground there, and that SHOULD be bonded to a cold water pipe, but not always, and sometimes, with the trends to replace copper pipes with plastic pipes a decade or so ago, sometimes the house grounds get separated from the water pipes via sections of plastic pipe, so you can't always count on that. So I'd check to make sure that your electrical service IS grounded to a water pipe.
Now you got me wondering about my setup...
I have my dishes on their own grounding rod which is not connected to the house ground.
Is this a bad idea?
I better correct this then![]()
Maybe not. If you have a grounding block ( blue color plastic for 2.4GHz frequency) on your dish pedestal and another in your house grounded to your house ground, simply disconnect the ground in the house from that block and use a meter to see if there is any current flow between the 2. If not... no problem.
If your dish is of any size and distance from your house you must ground it on its own rod(s).
Failure to do so will result in your coax being the ground conduit, your dish and all assemblies and your STB become toast... not too bright.
Ground returns are always present at your house, the power lines, your dish, etc... They are usually in the <2V ( if at all ) range. It won't kill you to string an insulated #4 copper between your ground points when you do your install if your that nervous.
