I've been wanting to get into FTA for a number of years, but have finally decided to make the plunge. I'm going to keep any threads I start to a finite topic though, and space them out, so a topic can be fully covered.
So, I'm wondering, if you were getting an FTA dish for the first time, knowing what you do about the satellites in the sky, and possibly looking to the future, what would you get for the KU band?
I've seen people suggest starting with a simple set dish of 30" or more, just to see if you'll like FTA. However, I wonder how many would want to continue with FTA if they could only access one bird without going to adjust the dish.
I've seen basic FTA starter kits that are pretty fairly priced, which include a motor, 30" or 36" dish (or larger), and LNB, with install kit. Unless you think installing a motor setup is a bit complex for a new user? Perhaps you would buy these separately though?
There is also the option of a multiple LNB setup. Adding an offset LNB is probably too much for someone new to the field, but there are pre-fab multi-LNB brackets, and eliptical dishes.
Of course, you could always go with a toroidal dish if you wanna jump in feet first.
Any special considerations you would make towards the LNB?
I've looked into it a bit and know that I don't likely want to start with a stationary system. Seems too much hassle just to upgrade later, and I'm interested in what I can see for feeds. I think I likely want to start with a motorized elliptical, with one or more LNB's. That way if I want to add more LNB's, it's easy, and I can space them for my most common setup, and still not be limited to set channels. If I was going to get a standard dish, I would want something larger than 36" on a motor mount, and would love a 1.2 meter...
