I'll check out 33/40 tonight to see if I see any problems. Meanwhile you can email
dishquality@
echostar.com with your PQ/sound issues. Be sure and tell them the actual satellite channel number (6495) and describe as best you can what you are seeing/hearing and also what time of day etc. Give them some time and they will respond.
I had success getting them to fix PBS channel 10 with that method.
The sad thing is I've only had Hi Def Receivers for 2 days, and can't get the local SD channels because the tech who installed my new dish took away my old dish. Another call to Dish and the tech is sending someone out tomorrow to reinstall my old dish so I can receive SD Channels. Go figure. :rant:
Sounds like they put you on the 1000.4 EA setup. Yep, definitely no SD locals on that setup. They'll need to get you on the 1000.2 WA setup.
EDIT: Just watched the channel. Definitely having sound drops and pixelation. I watched Wheel of Fortune for a few minutes and I'm already noticing them. So definitely not a problem on your end. All of you who are having that issue give that email a try. The more people that report it the more likely they'll quickly fix it.
