Happy New Year
. I've got one Dish Network receiver and two TV's hooked up to the receiver. TV1 is hooked into the receiver on the TV1 port by three RCA connectors (one yellow, one white and one red) and TV 2 has a Coaxial cable running to it in the master bedroom on the other end of the house. I have a third TV in the bedroom next to the master bedroom and wanted to be able to watch TV on it so this idea came to me
. I thought I could split the TV 2 Signal coming from the receiver to the TV in the Master bedroom and the TV in the bedroom next to the master bedroom. I went into the attic and found the cable running to TV 2. I cut the coaxial cable and installed two F connectors which grab the outter rubber on the cable. I found an RCA Digitial Technology Two Way splitter in the house and hooked the TV2 line coming out of the dish receiver into the input of the splitter and then hooked the existing TV2 cable in one output of the splitter. I went to Radio shack and bought 25ft of Coaxial Cable and hooked that cable up to the other output of the two way splitter and ran that cable to the room with the third TV. The room already had a cable running from the wall into the attic so I bought a F connector coupler so I could connect the exisitng Cable to the new cable I bought from Radio Shack. Now TV2 that had originally been hooked up to the receiver has a fuzzy picture on the same channel it was originally on CH.60 and the new TV has no signal on any channel on channels 21-69. On the receiver were the TV2 cable attaches it indicates TV2, channels 21-69. So is doing what I want even possible
. I want to split the TV2 signal to 2 TV"S. I will be watching the same signal from the TV2 signal coming from the Dish receiver on the two TV's that are in seperate rooms right? I hope I didn't make this too hard to understand.
Sincerely and Happy New Year,
John
. I thought I could split the TV 2 Signal coming from the receiver to the TV in the Master bedroom and the TV in the bedroom next to the master bedroom. I went into the attic and found the cable running to TV 2. I cut the coaxial cable and installed two F connectors which grab the outter rubber on the cable. I found an RCA Digitial Technology Two Way splitter in the house and hooked the TV2 line coming out of the dish receiver into the input of the splitter and then hooked the existing TV2 cable in one output of the splitter. I went to Radio shack and bought 25ft of Coaxial Cable and hooked that cable up to the other output of the two way splitter and ran that cable to the room with the third TV. The room already had a cable running from the wall into the attic so I bought a F connector coupler so I could connect the exisitng Cable to the new cable I bought from Radio Shack. Now TV2 that had originally been hooked up to the receiver has a fuzzy picture on the same channel it was originally on CH.60 and the new TV has no signal on any channel on channels 21-69. On the receiver were the TV2 cable attaches it indicates TV2, channels 21-69. So is doing what I want even possible Sincerely and Happy New Year,
John
