Single cable into home possible?
light200
93
I have a dual tuner and single tuner receiver and only want to run a single cable into my house from the dish for installation. Is this possible and if so do i need to use a multiswitch, which one, how could i hook this up? Its a Vip222 and a 211k.
MattG@DISH
3,871
243
Denver, Colorado
Splitting one cable won't work
Depending on the current LNB you have, you'll need to run a cable to each receiver (2 cables would need to be run if you're using DP equipment). What's the current LNB model you have? Press menu-6-1-1-check switch and post what LNB you currently have (listed under "switch").
adidas5482
102
6
None
I just did an install at the mall where I ran 1 cable from a 1k.4 to a 922 and 722k. Stacker at the dish and destacker by the receivers.
boba
11,350
1,036
Dorchester, TX.
What frequencies did you use to cover 3 satellites each using 950-2050
and how was that cheaper than running 2 lines which is all you would need for a 922 and a 722?
mdavej
971
47
Southeast
You can do a single cable install of DirecTV for free. It's simple and works very well. You can also watch your DVR from the other receiver. The only downside is they have a whole lot less HD.
dwarren2
4,076
287
Rochester, NY Region
What do you mean by "single cable"? I have a similar set up, a 722 and a 211. The cable is a single cable with 2wires, similar to a figure 8 with a single entry point into the house. Once inside the house, they 2 lines go into a grounding block and then a cable runs to each of the 2 receivers.
adidas5482
102
6
None
This is it
Dishman1978
3,274
90
California
That would be a dual cable.
KKlare
2,397
14
Los Alamos, NM
The dual cable often has a heavy grounding copper wire, which should connect to the grounding block and ground system, if applicable. It is just like 2 separate cables and the ground wire at about the same cost.
-Ken
Frank7004
715
Indiana
My guess is the OP has an apartment or lives some place that he only has 1 line to work with.
I have never seen a stacker/destacker kit (wish I would have seen one of these a long time ago) but from the sounds of it, it is the only option.
Typically, 1 line from LNB or switch to each rcvr (dpp) is needed.
322 installation need help.
Can we cut down on SD PPV?
