I definitely need an amplifier in the attic. However there is no noticeable difference whether I use the in in post 16 or the one i mentioned using earlier as long as the correct port is used for output to the room involved.
I did experiment with another amplifier in the room but it had no positive effect. Interestingly the issue with splitting the cable modem in the room was "solved" for now by using an ancient 3 way splitter I had. It has no makings indicating that it is two way etc but it is working for now and has been for about the last 18 hours. this surprises me because a DCC from Crutchfield led to occasional problems as did every other splitter I used in the room regardless of how they were rated..
Obviously I will continue to monitor this. I really am surprised that this splitter is working so i expect some incredulity from this crowd.
Ironically this may be less important than I thought. I am a satellite sub and was frustrated with OTA reception of one channel that has improved dramatically. That coupled with the fact that Cox has moved several local channels means I may be using OTA as my backup for the TV---although it is nice to have cable on the DVD recorder for the few channels that Cox allows me that satellite does not.
to those who want me to arrange for a service call, As I have explained I have been on the phone with Cox several times. It has been a comedy of errors as have most service experience with them over the years. The customer service there is the main reason i switched to satellite for TV years ago. If it fails completely obviously I will call them (or Verizon for DSL or FIOS) but I really don't se the point in dealing with them any further than i already have.
i know people have better things to worry about than this but i will report back if anything changes and i appreciate the advice.
What makes you think you need the amplifier in the attic? Is there something other then cable tv on those lines?
