How many DVR boxes should get?
Hunted Duck
Oct 6, 2011
23
I am switching from dish to direct and was wondering how many DVR boxes should I get? I currently have the 612 box I the living room and a 612 box in the family room for my 2 kids. We tape somewhere around 15 shows during a week. And the kids tape a few shows a month but like to have sponge bob on the Dvr. We tape everything in HD. Thanks for the help.
mdram
4,078
807
Md
i would get 2, just because it saves you $100 over finding out later you needed it
at initial purchase 1st is free, 2nd is 99
after initial
its 199 each
lparsons21
9,925
8,073
Herrin, IL 62948
Do you use the OTA tuner in the 612 for some of your recordings? If so, remember that each HR HDDVR from Direct can only record 2 events at any given time. So if you get 2 HRs, the max you could record at one time is 4 events. If you are getting the whole home dvr, 2 HRs might be just right. If you're not sharing video, then you might consider a 3rd one.
My useage when I was with Dish was that I often had 3-4 recordings going at once during prime time. When I switched, I got 2 HRs, one for me and one for my adult son and we signed up for whole home dvr. I found that for me having only the 2 tuners available to me was just not enough, so I got a 3rd one and stacked it on top of the original. So now I have 4 tuners for me, and 2 for my son.
Hunted Duck
Oct 6, 2011
23
Nope we don't use OTA. I was going to use a local retailer. They told me I can get 1 free HD DVR, and 3 free HD recievers. But I could get another HD DVR for $199. It that a bad deal?
mdram
4,078
807
Md
yes
the 2nd hdvr should be $99
Hunted Duck
Oct 6, 2011
23
Ok. If the 2nd DVR box should be $99 then how much should HD box 3&4 cost? Thanks for the help
rocket69
910
On Your Roof!
hd no dvr for 3 & 4 are $50 each mabe even less if you get the service through a local retailer who will be cutting out the sales guys pay as your direct contact.
35LKSA
103
2
Eastern PA
it appears that the HD-24 DVR's only support a single TV. Is that correct? I cannot connect a 2nd TV to the receiver.
mdram
4,078
807
Md
sure you can, but all outputs show the same thing
just get an h24 and use mrv to view whats on the hr24
then you have 2 sd tv's
Hutch1814
2,384
70
Indiana
Dish network uses diplexers to back feed (to make it simple) then in turn it sends the "2nd" tv the signal. Hints dual tuner. Directv requires a box at every location you want to watch tv but by doing this you're never tying up the 2nd tv when recording. If you go with just HD's in the other rooms you will be able to watch what's recorded however you can't pause, fast forward, or rewind live tv. Right now you're using 2 boxes to run 4 tvs so all 4 tvs can record, pause, rewind ect. so to keep this function on all tv's you'll need HDDVRs at all locations
Mr Tony
2,099
8,526
Mankato, MN
your market has both SD & HD available so you'd have to order specifically what you need
(some markets you can only get HD equipment....but those are newer markets launched. Columbus is a regular market where you can still use SD equipment)
Hunted Duck
Oct 6, 2011
23
Thanks iceberg. I talked to my local retailer tonight and I am getting the 2 nd DVR for $99 and the 3&4 hd's for free. Hard to pass this deal up.
