Is it normal for their to be voltage present on the coax shield?
coinmaster32
916
14
USA
I measured DC volts between the ground block for the coax on my Slimline dish, and a ground from a extension cord.
I'm showing 1.10 volts DC. Is this normal? I thought coax shield should be 0.
No, that is not normal. But, that is what can happen when you drive a second ground rod into the ground on the opposite side of your house. There is a difference of potential between the two ground rods which will equalize through the cables or equipment. The difference can be several volts, depending on ground conditions.
I have had problems with stray voltages long before I installed a ground rod.
Back when I had a C-Band dish, after a rain, I would always get a tingling feeling when working on the coax.
When I got directv, if I wet my finger and stuck it on the case, I would get a tingling feeling.
Although ground should be 0 volts, I don't think 1 volt is going to cause any problems.
I think your better w/ 0 volts than 1 volt. I would un-ground. Just my opinion.
:facepalm
H25-500 Tailgate Install Help
2 RF remotes 1 receiver?
