Hopper Installation Training Materials
gtal98 said:
Actually, scratch that. I'm assuming it is currently setup with the wing dish fed into the input on the 1000.4 LNB. Nothing changes, just take two output lines from the LNB and install the Solo Node. No 44 switch needed.
That is exactly my current setup.
Thanks for the feedback.
Right.
Several years ago I built my own roof mount platform because there was a possibility I'd end up with 3 dishes and I put three beautiful mount pads for 3 dishes in place ready to go.
Jump forward 6 or 7 years and I go HD and Dish requires their folk install the new dish. No prob. Long ago I quit getting a thrill out of DIY. Now I call some guys and point and write a check.
So the guys show up and first thing out of their mouths is that my mount doesn't meet Dish standards. So I tell them I built it, I own the house and they are not touching it. They can either swap out the new dish where it is or go back to their shop.
Guess what, the mouning platform is still there now sporting a 1000.2(or 4 or whatever).
Sent from my Toshiba Thrive using SatelliteGuys
Did I read the diagrams right? You will need 2 Sling adapters??
I just can't believe that will be the case. The whole philosophy seems to be, share everything, everything on the network is visible and shareable to all. Unless you want to block tuners in use from view........ ;)
navychop said:
Your concern for "up to code" is touching. I've had at least 4 installers visit at the two places I've lived with Dish, and none of them showed the slightest interest in grounding anything. I always run the coax for them, they always mount and aim the dishes and activate the receivers.
Gee, if I shift over to H/J, I wonder what the odds are that the installer will decide I need a grounding run?
Only if he was resently "written up" or put on a "feedback loop", this is mumbo jumbo customers need not worry about.
If the guy coming out wants to keep his pph high, he will fore go worting about the overly excessive QUAS checklist DNS requires installers use.
Shoot my install isnt even grounded nor is it 'upto code'. Its in it works and I have had no issues. I'd use your cable as long as its was rated to the correct freq range.
"Thou shalt not use RG59 to the Recievers"......
I agree. It's pretty simple. I have 3 lines coming in from my 1000.4 now that will go in to the Duo node and then out to the Hoppers and Joeys.
Exactly. All I need to do is insert a node between my DPP44 and existing lines going into the house, and swap my 722k and 211k for the Hopper and Joey. Badabing.
If you buy the equip you can do whatever you want: but if I roll out on a tc and you have a tripod screwed to a dog house hardlined suspension over to the eve: you will pay for the rebuild. Upfront.
Sent from my fingers.
No doghouses in my install. (And, I don't pay for anything upfront. Local vendors just don't do that around here.)
Maybe no dog houses - but it would still fail an internal DNS Quality check on multiple fronts: Only 4 lag bolts in the footplate (this alone is enough to fail, you need 6), improper grounding (Al wire not approved, the shiny DPP44s are not approved GBs so GBs must be installed between dish and switch, the mast/footplate is not grounded, can't verify ground source from pic), non-approved cable connectors (the black/silver PPCs are fine, the pre-made cable ends are not), some picky QAS might hit you for no service loops and improper cable clips too, but most wouldn't since there are no drip issues. All-in-all I could have your install up to code in about 30 minutes though, it's not terrible (assuming the ground source is approved).
The noob means well, Gary. However he's not as familiar with people here who install and maintain their own equipment.
No probs. You and I both know it's a perfectly fine user install. I've never lost signal in this, or my previous 3, homes. Good signal strength, too. And, nothing has ever fallen off, either. (If 4 bolts in the base, plus 2 on the tie rods, can't hold it to the side of your house, there's something wrong with your house.)
What's with the premade made coax? No way in hell I would use that for any of my equipment, not even to hook up a VCR.
I use quality premade all the time. Have for years. Works fine. Of course, if I was installing for a living, I wouldn't. I'd be pulling from a box, and crimping, obviously.
So you've had poor techs out? So what. That doesn't mean we all suck. For us it's a writeuo capable of getting us fired. Way to stereotype.
<img src="http://www.satelliteguys.us/attachment.php?attachmentid=74188"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=74189"/><img src="http://www.satelliteguys.us/attachment.php?attachmentid=74190"/>
Change out a few lag bolts to meet spec and a few of those non outdoor connectors and I'd leave this the hell alone. Excellent for a diy.
It definitely wouldnt be a big pita.
just wasted time.
Oh look it's this guy dumpinng on my posts again.
Great we have the opinion of such a fine DNS tech such as yourself....
Quit following me from topic to topic posting arrogant and condescending BS. You're not contributing only starting an immature argument.
This topic could go on forever.
I could get signal using a pie tin if I really put the effort into shaping it... Fact is though the standards are over the top and harm more then they help: they're there to protect you guys. From poor work. If you're too proud to realize it is a blanket standard with little to no exception you are missing the point. We don't enjoy the extra unpaid work. We loathe it; but it still serves to protect your investment. The majority of you do not have the means to tell a length of cable has a fail somewhere in the stinger nor that an lnbf has drift. So as I said; do the installation as you see fit but do not expect a DNS tech to bring it back up to code when he comes out. Or to work on it at all without compensatiion. We do this for a living.
Folks...
Please remember that SatelliteGuys is a website for Consumers run by Consumers. :) For those installers who value your craft and wish to discuss your trade we have a special forum just for installers. Please feel free to use that forum to discuss install techniques and procedures.
SatelliteGuys is proud not only to have America's Largest Satellite Forum for Consumers, but also America's largest installers forum as well. :)
Thanks for getting this one back on topic guys!
Scott Greczkowski said:
Folks...
Yikes the 5/0 jump ship!
Roger that.
I don't consider them poor techs. I just think grounding is maybe the first thing skipped. I'm not trying to insult anybody.
Well grounding won't make your system go out in week. Poor mounting quality (to tin roof not striking a stud or beam) will.
I don't follow it all to the T myself but I do make sure it will last. Just want to make sure I do quality work.
Such as that done by the MoCA engineers (suddenly back on topic)
Quite an ego you have if you think I'm following you around.
Back on topic
It shows a single-node coming directly from an LNB for a single-hooper/single-joey setup. But, I would need to continue using my DPP44 switch with that setup because I have a 1000+ setup for International channels.
So, can I just hook two outputs from the DPP44 to the single-node inputs?
Yep. That would be the way to do it. Or 3 lines to a dual node, and you still have one left over if you end up being able to keep a ViP receiver.
HDCP Problem With 612
Alternatives to Hopper/Joey for 2 HDTVs
