compatible, does not mean completly functional.
Okay. So, what does compatible mean in this case?
A tailgater will work with every single receiver besides hopper. It will only supply signal to one tuner at a time. So you run the cable to satellite input 1 on your box without a seperator or triplexer and you run a checkswitch and viola you have TV, just not able to use both tuners.
Compatible is, it will work, does not mean all features will work. For instance, the GM "On Star" is compatible with most newer cars, you can buy it and install it, it will work. But, not like it does when it comes installed in a GM car. It will not support all the features.
The 211k is the only receiver that has the software to control the Tailgater.
Your question was answered.
So you asked in this case what does compatible mean. Going by the DIRT response, it means you will get some features, like being able to actually get a signal, but it won't have the software to control the aiming. Like the On Star example, some features will work, some won't. Compatible by the way does mean exact.
Even the Dish website is a little unlclear, only saying the other models "can be used."
Next time make it clear you only want a specific person to answer and I won't waste my time.:
That would be hard to swallow.... Dish wants full price for the 211k and then will restrict customers to use it only with a Tailgater ? For some people, that might only be a dozen times a year.They did not say, but is the 211 usable only on the tailgater portable dish, and not to be connected to your home Dish/Hopper system?
Can't a user still manually aim their dish ?The software referred to is to direct the dish, to aim it. Only the ViP211K has that. Well, maybe the ViP211 also.
The Tailgater will work just fine with the 211 or 411. The 211K is suggested so you can take advantage of Dish Network HD. So I guess there is a reduced functionality in that sense if you chose to go with the 211 or 411.
Regards,
King Controls
That is just so WRONG! The only difference between the 211 and 211k is color and size. The only difference between a 411 and 211 is the lack of a network interface on the 411. All 3 receivers are HD receivers, so there is no "reduced functionality" to speak of. Unless somebody has found a significant use for the network interface on the 211/k out in the sticks.![]()
king3pj said:Now that this is available I am planning on having an EA dish installed at my cabin on the lake in Northern Michigan sometime in the next few weeks. My neighbor up here has a 211 and he still gets our flint locals back home which is about a four hour drive away so that's why I want EA.
Since its Saturday I was only able to get a hold of one installer. He says that they usually do WA installs here and EA dishes are more expensive so he wants to charge extra. It would probably have to be pole mounted to get under the trees and aim out over the lake but I should have a fine line of sight. There is a chance it could go on the roof but I'm not sure if the trees are too low. My next door neighbor has his pole mounted and we have similar properties and line of sight.
The house is extremely close to the lake and the cable would only have to run about 25 feet to reach the tv with plenty of slack. He says it will be about $250 to $300 plus another $150 to buy the 211k. I told him to forget buying the receiver because I know I can get one myself for less than that. This makes me question the rest of his pricing though. Is $250 to $300 reasonable for this kind of install or should I be looking elsewhere?
