Since we are unable to replicate this issue with our set-ups, it will be rather difficult. I have connected the microHD to the scope and only observe the typical reissue of the USALS/DiSEqC/22khz commands.
Maybe try a motor hardware reset and also perform a "Recalculate" with the microHD when connected to the motor.
Anyone else using a DG380 motor with the microHD?
I just put my DG-380 on the MicroHD to test this.
1. Put the dish on Aljazeera . Blocked the signal with a big piece of cardboard--no motor movement.
2. With the dish still on Aljazeera, I disconnected both RG-6 cables from the lnbf -- no motor movement.
3. Reconnected both RG-6 cables to lnbf-- motor moved about 5 degrees West, then back to 97W and stable.
It appears that once the lnbf feedback is re-established, the motor movement commences, whether ordered by the MicroHD, or not, I can't tell.
Moving my MicroHD to a SG-2100,
1. Block signal, no change in the motor .
2. remove cable from lnbf, after about 5 seconds, a tiny sound from the motor, like it was being "micro-bumped".
3. Reconnect cable to lnbf, tiny "micro-bump" sound from the motor.
Neither 2 nor 3 resulted in dish movement, just brief motor energization.
Suggest that loss of lnbf feedback triggers some response from the MicroHD. That response signal is interpretted slightly differently, depending upon motor model.
