OTHER Motor movement behavior
videojanitor
276
66
I've been ignoring my FTA system for a while and just started to tinker with it again -- I'm amazed at how much I FORGOT -- it was like starting from scratch. My equipment:
Edision OS Mio+ 4K (running TNAP 5.1)
GEOSATpro 36"
Stab Rotor Sat HH90
I was able to figure most functions out once again, but one things has always perplexed me: While in DiSEqC mode, if I attempt to use the "Step East" or "Step West" functions, the motor will sometimes take off and swing all the way to the west end of the arc, and then comes back. For the life of me, I can't figure out a pattern to it -- seems to be totally random. Could happen after one button press, or ten. Just wondering if anyone has noticed this behavior, and/or if there's a reason for it? Am I doing something wrong?
Thanks!
I've never noticed that. There are two positions: Movement and Fine Movement. When Movement is selected, then the motor will move continuously in one direction when you press Search West (green) until you press it again. Same for Search East (yellow). In Fine Movement, the motor should move just one bump when you press Step West (green) or Step East (yellow).
Yes, that's my assumption on how it should work. I should have clarified that I have "fine movement" selected when attempting to nudge it east or west. I wasn't sure what was happening in the beginning, but after connecting a spectrum analyzer it became obvious that it was sweeping the arc. Puzzling.
I can't be certain of that as I'm a bit of a rube when it comes to keeping up with the latest updates. However, I did just install 5.1 a few days ago (20240729) and assumed it was the newest build. This behavior has been going on since the day I installed the dish, maybe 3 years ago.
Then maybe it's a dish issue. I'm not familiar with Stab. My SG2100 has a manual reset button on it. With your symptom and my dish, I'd try resetting to see if that fixed it.
I believe that the usual cause of a motor driving all the way to the end of the arc is a stuck relay. It doesn't usually correct itself though, so I don't know if that's what's going on in your case.
Are you speaking about a relay that's inside the motor? If so, that might be difficult to replace. All-in-all it's no big deal as I'm just futzing around with the whole thing. One other annoyance I've come across is that after doing a blind scan and exiting the menu, the Edision shuts off the power to the LNB. If I select a satellite/channel to go-to, it powers back up. Could be a setting for this somewhere …
Yes, if I remember rightly, there are two relays, one for each direction.
The issue with shutting off LNB power at random is a known thing that nobody seems to want to fix. (IF it's the same problem -- on mine, changing channels does NOT fix it, I have to restart.) The "solution" is to select one of the other tuner drivers -- I think it's the no-T2MI one that doesn't have the problem. You won't miss any channels in North America without receiving T2MI, but there have been times when I've thought that the blind scan on that version of the driver wasn't as thorough as the other one.
The STAB HH100 has a solid state relay; maybe the HH90 also? Then no stuck relay contact.
I've no idea about the cause of the problem, too, though. STABs do seem to have strange problems now and then, which I don't read about SG2100 (Moteck) motors (which have mechanical relays).
Greetz,
A33
Interesting. This doesn't seem to be the same as the only reason I noticed the LNB being powered-down was because I had the analyzer connected. Once I select a satellite or favorite, it power right back up. Thought it might be desired behavior, but couldn't think if what that might accomplish.
OTHER Configure a location in plugin settings
