usals and the microhd
mucketbucket
31
louisville,ky
I have the microhd and a 10' dish with a dmx741 lnb. I have it set up with 2 cables using the encoda splitter that came with it. I am using the ku and cband setup currently instead of the universal setting. Will the usals setup work with this?
How are you controlling the C-band dish actuator? G-box, V-box or a BUD receiver? USALS does not control a V-box / G-box.
I don't think that the DMX741 is an Universal type LNBF. Are you wanting to use the Universal LNB setting "UNIVERSAL 5150/10750" with the Ecoda switch?
Thanks for the reply AV,
I am using the vbox to move the dish and I did not see anywhere that it said it was usals compatible is why I was asking, just thought it might work somehow. The 741 will do universal but it doesn't report the tp#'s correct when viewing the channels, plus some of the ku's are a few clicks off from cband so I just don't use the universal setting.
The V-box can be directly controlled by the microHD using DiSEqC 1.2.
If the TP frequencies are incorrect, an incorrect LO has likely been selected.
Universal setting only indicates that a 22khz command is automatically issued to switch between the low LO and the high LO.
microHD Unresponsiveness Quirk
Move on he Clark Belt and then Record?
