Hi,
I have a slimline 3 dish in my main home in Phoenix with 1 H24 and 3 H25 receivers, I bought a slimline dish kit and installed that in my weekend home in Payson Arizona. This came with a power inserter, 8 way switch, etc. So a few weeks ago I installed this, hooked up a H25 receiver from my main home and I cannot get it working. I have aligned the dish to where it says the satellites should be for my location (85541) Azimuth 151, Elevation 50, Tilt, 105.
I spent all last weekend on it - I had a cheaper meter but nothing I did could increase the signal on the meter. I figured there might be something wrong with the cable, so I bought a brand new 100 ft cable and tried that - no progress always giving a 771 signal.
I took the LNB and power inserter down my main home, plugged them in and they worked first time.
I bought KU / KA meter (DSF120+C) and tried to align with that, when I plug it in I get it to go to 99% and then I press att (to attenuate) to get it down to about 60% but no matter what I do to further align the dish, I cannot change the signal strength.
Running the system info & test fails with a diagnostic code 41-732 (Satellite Dish alignment or distribution problem)
I hear these dishes are difficult to align, but surely I would get some movement.
Until a few weeks ago I knew nothing about Satellite TV, but I am learning. Should this simple setup work?
1. Dish aligned to the approximate azimuth, elevation & tilt.
2. New 100 foot cable going directly from the LNB to the power insert port named (power to SWM)
3. Short cable going from the power inserter port named (Signal to IRD) to the H25 receiver.
The Power light is on the power inserter.
Do I need the 8 way switch if I only have one receiver?
Does anybody have any advice for me?
Many thanks,
Andy
Many thanks,
Andy
to Satelliteguys AndyE!
