SL3 non-swim
Will my receiver work on the road with a DTVP3 LNB but i have a SL3K4NR0-02 LNB at home.
What recvr ?
The 1st one you mention is an old 18x20 dish LNB, you would get then programming on the 101 core Sat, all SD.
The second one you mentioned IS a SL3, but Not SWM technology, which is fine as ling as you can run more than 1 line to the recvr, (provided your using a DVR that is).
But Yes, this one would work in most cases.
I think (could be wrong) this is a SD box , not HD, IIRC, therefore my previous post is not helping you .. If it's SD, then you'll only need to his the 101 Sat for the core programming, the 110 has nothing on it and the 119 has limited use, some locals and some music.
Therefore if this IS SD you don't necessarily need the SL3 set up as it won't see the 99 or 103 Sats.
Slimline 3 alignment - tried everything I really need help
HR34 + 2 HR24s
