LET'S TALK ABOUT SWITCHES
techristian
11
6
Windsor
Ever since I have had an S2 switch and 2 dishes I thought the rule was the same for 4 way/ 8 way switches. C band sats TURN OFF 22K, KU band turn on 22k (in settings) but according to some sources that isn't true. 22k should be turned to AUTO for 4/8 way ACCORDING TO SOME SOURCES. Even though I got most of the bugs out, some funky things are happening. I'm not getting all of the channels. I DON'T HAVE AN AUTO setting for my 22k tone. I have been doing this more than 15 years and so I'm baffled.
My AMIKO doesn't have a auto setting for 22k. Sometimes it lights up BLUE and sometimes it doesn't.
Dan
The only time the AMIKO lights up blue (22k off) is when you have setup a universal LNB. Only if you have a 0/22KHz switch between your LNB and your 4 or 8 port DiSEqC, and have another LNB on the other side of your 0/22KHz switch, do you need to set the LNB to 22k on or off. (There is the one exception, if you set up a universal to only scan one section of the bands it can scan).
Otherwise, there is no point in turning on the 22k when using a 4 or 8 point DiSEqC switch, in fact, it just add extra unnecessary commands to selecting ports.
Can anyone guess what the real problem was?
Users Who Are Viewing This Thread (Total: 6, Members: 0, Guests: 6)
