What does this mean???
Hall
18,409
3,199
Germantown OH
Safe to say this only applies to receivers that support HDCP? Someone with a 522 or 311 wanting to watch those channels will still be able to, I hope.
Sent from my SCH-I535 using Tapatalk
mike123abc
Too many cables
25,357
4,604
Norman, OK
HDCP is High Definition copy protect. The standard definition output does not have to be protected.
mike123abc
Too many cables
25,357
4,604
Norman, OK
I think you just made that up... 'cause that's not what it means.
http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
High-bandwidth Digital Content Protection (HDCP), commonly referred to as High-Definition Copy(right) Protection, is a form of digital copy protection and digital rights management developed by Intel Corporation[1] to prevent copying of digital audio and video content as it travels across connections. Types of connections include DisplayPort (DP), Digital Visual Interface (DVI), and High-Definition Multimedia Interface (HDMI), as well as less popular, or now defunct, protocols like Gigabit Video Interface (GVIF) and Unified Display Interface (UDI).
Note what it is commonly referred to as...
Also in regards to standard definition on Dish. If it locked out the standard definition and only allowed HD via HDMI, we would have heard a lot more screaming as all the SD receivers would have stopped working for these channels.
Scherrman
15,555
9,951
Eastern Iowa
I was just going to post that link to wikipedia. Most people think of it as meaning High Definition Copyright Protection. I myself figured that's what it stood for until I looked it up.
dare2be
SatelliteGuys God
12,742
7,775
FL
While we were on the off-topic subject of acronyms, I once asked my daughter (9 at the time) what LED stood for...she didn't know but gave it a thought for a few seconds and said: "Low Energy Device?" :D
lucky86
3,941
179
By the sea, in a land called Honalee
That message doesn't mean he needs an hdmi cable, it means he's using one. His tv isn't hdcp compliant or if using a switch or splitter that could be causing it. Remove hdmi and use component and the issue goes away. What tv make model and year manufactured?
GaryPen
Rich or poor, it's good to have money.
Actually, it could be caused by a bad HDMI cable.
Martinash
70
3
Chicago
You say "you need HDMI cable connected". Meanwhile, i experienced exactly opposite. Customer had 612 connected with HDMI and mirror TV connected to coax output. HBO channels would give him this message on mirror Tv unless main TV (HDMI connected) was on. Solution was to replace HDMI with component+optical.
