With the impending arrival (pleeeeeeeease let it be soon!) of my new red Amiko A3 I am trying to work out how I will go about redoing EVERYTHING..
Several of my dishes will have dual output LNBF's so they can also feed a secondary system but we won't worry about those right now. So let's just pretend everything is single output for now.
The dishes. I have the 10' C-band. It's motorized but currently the Gbox is not "in the loop". No device I have can move the dish except the Gbox which is stand alone right now. The cable does not pass through it, the only wires connected to it are the motor control wires. When connected to the PC, the PC would send random commands to it and cause frequent flop overs. I had to remove it because of that. As of now I can only move the dish with the remote control or the push buttons on the box.
I would like to put the box in the system properly so that the A3 can move the dish on demand as it needs to.
I have the Prodelin 1.8m that I am planning to convert to a C-band minibud. Most likely I will parked it on MeTV since they have a more stable signal than RTV. I figure the DVB-S will be less temperamental. In the past I've had miserable luck with RTV's S2 signal even using a 10' dish.
I plan to install another HH USALS 1m KU dish for the A3. (I have one now in use for my MicroHD and I want to leave that as is.)
I have assorted fixed KU dishes that I want to put on it as well. One for 97, maybe one for 103, one for 125 and a spare. Just because they are already in the ground and I get annoyed waiting on those stupid "moving dish" messages to clear. I also like the instantaneousness of fixed dishes. And as much trouble as I've had with motorized dishes, I want them to by my primary dishes and the motorized KU dish as a backup and exploration dish.
As far as I can figure it, I have to run the HH motor on the 0k side of the 22khz Ecoda switch. So when I want to view something on it the tuner only has to concern itself with sending a USALS only signal to it.
EVERYTHING else, I believe, should go on the 22k side of the Ecoda. But what I'm not sure if I can do is have the Gbox in the system too. I was thinking it can be used as a GOTO-X controller. So to move the dish on the C-band arc I would send a 22k on AND a GOTO-X. I'm thinking I can put the DiSEqC (I BLOODY HATE THIS WORD! I CAN NEVER SPELL OR PRONOUNCE IT!!!
), the BLOODY STUPID DiSEqC switch in there as well to give me eight uncommitted DiSEqC ports on the 22k side.
I really hate this stupid word, DiSEqC I have to look it up on google every single time and copy and paste it. This is the STUPIDEST WORD EVER INVENTED!! GRRRRRRRR!!!!!!!!!!
ANYWAY........
So to watch MeTV I would need (assuming I assign Gbox position 10 to SES 1) to send this signal,
22k on, uncommitted DiSEqC port 1, GOTO-(10)
BUT, to watch RTV on SES2 which is a fixed dish it would be,
22k on, uncommitted DiSEqC port 2 (no goto command needed, not motorized)
To watch something on 97w it would be 22k on, uncommitted DiSEqC port 3
etc....
I don't see an issue with stacking two commands such as the 22k and the DiSEqC commands but what about adding a third command, the GOTO-X ??
Will the Amiko A3 let me do this? I know for a fact that I can do it with my PC using that deadware 'MyTheatre'..
I want to get rid of the PC completely (I have other plans for it) and do this strictly with STB's..
I also plan to put an SiliconDust ATSC OTA tuner on the A3.
Can I do these things? What happened to the resident switch genius ?? Anole? If anyone would know it would be him.
Thanks!
Edit: Another option I've discovered since reading up on this DiSEqC stuff, if nothing else, what about an option to send customized commands to DiSEqC devices? From what I read, the tuner sends some HEX codes that the switches respond to and in complex, stacked systems you can stack the commands to get complex results. So I'm wondering if the A3 will have the option to send custom DiSEqC commands ? If it won't let me stack three commands like above, maybe I can send it custom commands?
Turns out my switch is a Digiwave, not a DMS like I used in the picture. So my switch is a DiSEqC 1.1 - 8 ports all uncommitted . uncommitted 1 - uncommitted 8
I'm sure this is a very important point when it comes to chaining/stacking three DiSEqC devices.
ANYWAY........
etc....
Thanks!
