Jimbo: Apologies for the delayed response. Park WiFi was out for a bit and I decided to watch NFL stuff off air this weekend.Ok, if it only has 1 output, its a SWM, thats good, its either a SWM 3 or 5.
Are you running the Repeat Sat Set Up ?
It should automatically pick up the SWM and switch from Multiswitch to SWM, but this is where you can check.
The LNB is a SWM 5. Did setup this AM. It did automatically p/u the SWM 5. I have 80's and 90's on (101 W) (all but 2 tranponders). Howsomever, 119 and the others were all labeled N/A. Tilting the dish to D* recommended 106 deg only took the 101 W values down to the mid to low 70's. When I finally (out of frustration) selected DONE, The only satellite that wasn't RED Xed, was 101 W. The channels which I get (25% maybe) are mostly HD).
I have no idea how to proceed. I did the Az & Skew dithering, so I can't get any better 101 w reception. But there "obviously" is a bunch I still don't know.
