Which one is real? The second one does not look right.
The first one came in packaging like this:
How do you spot a fake?
They both look like Chieta switches. The larger one is their lower loss version. Seesat made a similar switch in both the small and larger lower loss versions. I have used the larger versions of both the Chieta and Seesat switches and have not noticed any difference in them. I have not used the smaller versions of them. (have only used them in simple switching uses and not in complex cases with motors)
YesThe lower loss version being 1.5 db as the first picture is labeled?
thank you very much for pointing that out Larry1They both look like Chieta switches. The larger one is their lower loss version. Seesat made a similar switch in both the small and larger lower loss versions. I have used the larger versions of both the Chieta and Seesat switches and have not noticed any difference in them. I have not used the smaller versions of them. (have only used them in simple switching uses and not in complex cases with motors)
Ever consider getting the Amiko switches from fridgeFTA? I'm happy with what I've gotten from them.
