working in a college proyect, need some help
tavarezcomm
cuba
im doint a sollege project, the main idea is of course if is possible) to take from a directv receiver with a paid subscription (of course) and trough some device or software to every single channel that i am paying for to open it in a media player like vlc or in any media player.
the idea is to open it all at the same time in a pc.
thanks
No, can't be done like that. Each directv tuner only decodes a single channel, there's no way to take them all at once and do anything useful with them (since the signals are encrypted)
well, if you're needing to watch more than one channel from this receiver at once, then no. however, using the HDMI output i think i've figured out a way to record the stream onto a computer. costs about $1500 in parts though. purely theory at this point since i've not pulled the trigger to try this experiment though.
what channles?
Specifically it's referring to a com2000 headend system like in the photograph.
Which is comprised of "com46" plug in modules. Where each module can simultaneously receive up to 8 different DIRECTV program channels, and the chassis they plug into can accept up to 6 of these modules.
Therefore 8 x 6 = 48 channels max.
Sent from my SGH-M819N using Tapatalk
Reactions: Tecnicoloco
What Claude shows is how "cable" is at my grandmas
Its DIrectv but there is a "headend" in the basement with receivers. They output stations to different numbers (2-39) and its all 720p (even if the station is 480i ala GSN).
This works great for the complex as I dont think you'd want to deal with old people (this is an assisted living facility) and Directv receivers in each apartment.
They have a set list of the most common channels (except for one of them...its INSP during the week and RFD on weekends) and if folks complain enough they will change out the channels. They got rid of Nickelodeon and added I think Cooking channel.
(only drawback is they dont have BTN and if there is a game on FS North + its not there. Funniest thing is when ESPN2 has the same college football game as ABC does the receiver "defaults" to ESPN2 alt. So from Saturday night until Monday when the maintenance guy is there ESPN 2 shows the Directv screen)
The other oddball is NBC (which is channel 11 locally) is on 10. I think that is because from 2-10 are the locals (the legacy UHF stations are on 6,7,8) and then the cable stations start at 11 (and unless a station is switched out they are in alphabetical order)
Com2000 or are they using zeevee with no encryption?
I doubt there is any encryption. We just hooked up the cable to the wall and boom there was TV (its included in the rent)
odd that a box in a hotel like setting is doing a auto tune like that. What does the com2000 do? directv residential experience?
If it's like the assisted living my Mother is in, they just disconnect a line and re-connect it when someone moves into the appartment. Really messes with the signal though when too many ports are open. Her's isn't included though.
Reactions: Mr Tony
What you want to do was sort of possible with cable. A multi stream cable card pci-e card could be put in a computer. Then up to 6 channels could be watched/recorded on the computer from the cable connection if the cable card supported 6 streams.
With directv the closest you can get is 2 channels with PIP on a genie. If you do not need to do things real time, using a genie you could record 5 channels at once and play back the shows that are important to you and record them to the computer. Then you could tile the recorded files while you played them back. Unfortunately you would still be limited to getting 24 hours of video out in a day without paying extra for more clients or receivers.
Hauppauge makes several products that would let you get HD video into a computer (the HD PVR line and the Colossus line). With a couple of those and a stack of satellite receivers you could get a bunch of channels into a computer real-time and display them, but for every channel you want to show you need a subscription for a box.
If you need to build something to show proof of concept, SD capture devices are cheap. In place of directv boxes you could use FTA boxes or OTA DTV converter boxes.
I dont know honestly. I wondered it myself when she moved in there. All I know is you hook up the TV, select cable and scan. It shows as analog numbers but its 720p (all stations)
There are video dropouts on the system though. It sucks trying to watch a Vikings game and get a black screen for a second about every 8-10 minutes or so
I had a similar set-up about 10 years ago at an apartment building, about 50 units. It was the only service available available in the building and it was not included in the rent. You just plugged coax in the TV from the wall and you had cable, if you paid. Analog TV was still on the air and Lifetime, ch 3 on the Dish Network-fed system, ALWAYS had WCAX (CBS) analog in the background, no matter what you did. There was a weird FM-stereo-hiss effect, too, on the channel. All channels on the system were SD and mono audio, but the OTA broadcast interference did strange things to it. If you didn't have the service, it would just be static, with WCAX nearly clear as a bell on ch. 3. I assume the wiring in the building was getting the signal. You could see WPTZ (NBC) 5 but not really watchable. My neighbor only had channel 3, courtesy of this after I told her that it would work for just that channel.
I had an old set of rabbit ears, a decent indoor amplified antenna that I don't remember what it is, with a cable input in the back. I discovered that if you put the switch exactly halfway between "cable" and "antenna" it would work for both. It had no effect on the quality of the cable reception and only a small effect on the OTA reception. In fact, the WCAX-Lifetime situation improved (well, sorta - it meant Lifetime was clearer) because I could put the poles of the antenna all the way down in a manner that kinda put WCAX in a null. It could also blast over Lifetime enough that my ex wouldn't watch it if I left the antenna in the proper set-up. The UHF OTA channels (TBN W16AL 16 also fed by Dish Network, WVNY ABC 22, WETK PBS 33, WFFF Fox/WB 44, WGMU UPN 39, and WCFE PBS translator 46) would show up higher up on the dial. It was weird! The cable lineup stopped at channel 28 or so if memory serves, with WCAX, WPTZ, WVNY, WFFF and WETK being hte last channels in the lineup. I kept WCAX and WPTZ from the cable but programmed it to go to 67 for TBN, 73 for WVNY, 84 for WETK, 90-something for WGMU, 100 (or 99) for WFFF, and 105 or something for WCFE. The OTA channels were stereo, and the cable were only mono, so it was an upgrade. The OTA picture was better than the cable channels (except WGMU and WCFE which were bad - but bad is better than not there). Nothing was HD, but from 2005 to 2007, one would not expect it to be.
Often the cable channels would freeze for days at a time. It would take someone (often me because I was unfortunate enough to work closest to the landlord/cable office but not always) physically going there and not leaving until it was fixed. We did not have NESN or the former FSN New England on the cable. ESPN and ESPN2 were on there and there was no switch to the alternate if needed. Truly a terrible system. It has made me VERY leery of any such system until I started seeing Claude's posts.
