Looking for suggestions?
bpalone
631
424
44N 105W
Just got approval to take this antenna down. Look at the photo, somehow they melted the LNA cover. Any thoughts on how to at least get enough off to get at the bolts?
channel lock pliers. Start pealing it off from one side and work your way around.
(That must be one HOT lnb there)
Yep, if it's really melted. Lighting, seen much worse, could not even find the feed and half of the button hook left worse case a dog died, I ran the ribbon cable back to the house, it was a fiber glass dish very hard to ground lighting went into the guy's house which burned all his equipment up, could have burned his house, it was snaked by the owner in the wall he didn't want to see the wires, it pushed out his wall
Ok, now the wire ran over a root to a tree next door, and the tree had a steel cable which was for a dog run it killed the dog, sh*t happens
Thanks Fat Air!! Used your method and a screwdriver. Got it to where I can get at the bolts now. Now to let some other bolts and nuts soak in some PBblaster for week or so.
Thanks again.
Reactions: FaT Air
Mini Bud.
10' BUD
