New install - lost signal for a few minutes during the rain today
magnumis
23
Midwest
Yesterday I had a new install of an HR54. Today was the first rain and we lost the signal for a few minutes.
The rain is gone and the channels are working again. The following are the signal strength from satellite 101:
1-8 96 98 97 82 98 100 98 100
9-16 98 99 98 0 99 100 98 100
17-24 98 0 98 52 98 100 98 100
25-32 97 0 97 86 98 100 97 100
Are any alignment adjustments needed?
That is excellent signal for 101. With those kind of numbers I'd imagine 99 & 103 are good as well?.?.?
Which 99 and 103 should I check. There is 99 (ca), 99 (cb), 99 (s), 103 (s), 103 (ca), 103 (cb)
What does ca, cb and s stand for?
Thanks!
i notice your location says midwest. we get some very powerful, very small cells of weather moving through. intense thunder, lightning, and rain for 10-20 min at a time. losing signal for that is normal.
Here are the other number:
99ca:
N/A N/A N/A N/A N/A N/A N/A N/A
N/A N/A 95 N/A 95 95 95 0
94 95 92 95 0 N/A 95 N/A
99cb:
95 94 89 88 94 91 91 88
93 93 91 89 95 94 n/a n/a
99s:
72 0 73 85 0 0 0 86
na na na na na na 39 97
97 98 98 98 97 96 46 60
103s:
0 0 0 0 na na na na
N/A N/A N/A N/A N/A N/A 40 87
90 89 92 91 13 0 47 42
103ca:
95 94 94 90 94 91 91 92 92
94 91 95 92 92 91 95 93
103cb:
95 95 93 92 90 91 93 91
92 90 92 93 93 91 na na
Those are good signal strength numbers. Although they could be a little higher, you will still lose signal in a fairly strong rain storm for a few minutes, maybe a little longer.
99ca:
99cb:
99s:
72 0 73 85 0 0 0 86
103s:
0 0 0 0 na na na na
103ca:
103cb:
They look good also. It would be really hard to get them any higher, especially without a meter. Your signal loss isn't because of an out of tune dish, just weather related.
Give us a zip code and we can pin point a bit better.
You have a few options when this type of thing happens, often times channels from a different transponder may still be working, try a different channel.
Or, switch your set up to SD channels, instead of just HD, doing this will allow you to tune to a SD channel and that may be still working.
HD signal is much tighter as it's on a different band.
Reactions: ejb1980
To add a little for more the OP: You probably won't lose the SD signal, except for like the darkest red on radar. I switch over to SD if I lose the HD signal to a storm. I have only lost 101 (most of the SD channels) a handful of times in several years of service for merely seconds at a time. I have also only lost the 119 (mostly Spanish) a few times in several years. But 103 and 99 (Where nearly all the HD channels are) are the first to go in a storm.
If you live in an area that gets snow, light fluffy snow does nothing to the signal. It can accumulate lightly on the dish and all is fine. Ice/Sleet/Heavy snow is like a storm and will kill the HD signal quick, but if you keep it brushed off it's not as bad.
Reactions: Jimbo
Any new software coming?
Playlist: Recently Watched on Demand
