I need 11 receivers at new house!
csloan1981
73
5
Arkansas
HR54, 3 clients, HR24, and 6 H25's could I use this setup without a switch and just use a reverse band lnb because one of the clients is going to be a C61?
That should work for the time being, but I think Directv figures for 7 tuners in an HR54 since it will use that many once UHD is fully implemented. I'm sure one of the installers will update my post soon enough.
Yes, that should work perfectly on a RB LNB. The 7 tuners doesn't exist as far as we're concerned and if I remember correctly the extra 2 are reverse band only so they won't count against the 13 tuners on the LNB.
I assume you mean C61K, there is also a C61 which is not 4k.
11 receivers? wow, i cant imagine ever needing that many
gonna be one expensive install
No
The HR54 takes 7, HR24 takes 2, plus 6 tuners for the H25's is 15 tuners.
You need a DSWM 30 and run the 2 flex ports to the dish for the reverse band Legacy LNB.
Like I said, it will work for the time being, until UHD is on linear channels.
USA to Mexico
Whole Home will not turn Off
