Dish receiver kaput after elec company shuts down then turns power back on for city power upgrade
Gaze
37
16
The local electric utility company shut off power to my dad's neighborhood for about 10hrs as part of their big system upgrade project. When they turned power back on, despite being on a power strip with supposed spike protection, his Dish receiver no longer works. No lights/signal, nothing.
His receiver is a very basic VIP211K model. No DVR. He's renting the box from Dish monthly.
Posting this to ask about the easiest procedure for getting this replaced, or possibly if there's a reset of some sort can try to get the box working again. Thanks.
If it doesn't come back after the above procedure, just call dish. They will replace it. Depending on how long he has been with them, they may even do it for free.
Reactions: pattykay
Yes, even if you do get the receiver to come back to life, usually receivers that have started having this problem do not last very long before they die completely. A replacement may be your best option.
Can't sat that's ever happened to me, either at home or at work, but it is an additional line of defense between the incoming power supply and your stuff.
I've got 4 APC UPS's right here in my office and they've been protecting things for years. Years ago we had a major power problem and the one of the UPS's failed but everything that was connected to it was fine.
On two separate occasions lightning hit a tree in my backyard. In the first situation I lost some electronics. In the second several surge protectors anda UPS gave their lives to save whatever was connected to them. The tree is gone now but I still swear by power protection.
If those UPS are over 3 yrs old it's a good bet that the batteries won't hold much charge. They are easy to replace. You might want to test them to be sure they will hold a charge.
UPSes generally warn you of failing batteries. If yours doesn’t, put a pry bar on that wallet and buy a good one.
Consumer level UPS's aren't usually very good at warning about the battery until it is completely gone.
I use the following in my setup, which one to consider good?
-- APC rack-mount
-- APC tower
-- Tripp-lite tower
Stopped using CyberPower after a couple of premature failures.
Thanks for the replies guys.
I tried all the suggestions above, but this thing seems completely dead in the water. The prongs on the plug look fine (no sign of being burnt).
I'll contact Dish and ask for replacement. Was hoping there is a fuse or magic reset button hidden in the box somewhere.
Wow, the fuse replacement comment takes me back to the 60/70's. We used to keep buss fuses around for our receivers. Thanks for the trip back in time!:angel2
hah
you're welcome :biggrin
btw, how does one sign up for the protection plan? via the website I couldn't locate it.
There is a fuse under the cover. You need a screw driver to take the cover off
Reactions: TheKrell
